kaku here, you can start here:
TIPS FOR those who already upgrade block to V-Ixion block :
1. Dont forget to change the Cam (stock vixion cam / my super cam) followed by pilot jet stepped up to #22,5 and Main Jet #105/110
2. Carb change to MIKUNI TM24, TM28, KEIHIN PE 28, PWK 28
3. Change CDI & ignition coil
COMMON TIPS:
1. Dont install the lower cyl gasket, use threebond sealer instead, then check ur valve clearance, is the piston still within safe clearance from valve at Top Dead Center (TDC) position and not collide with valve by rotating the crankshaft counter clockwise 4 times (to the top position marked at the cam sprocket)
2. Take off the decompression assy on cam sprocket.
3. See that engine breather rubber pipe from water pump that connects to air box? Unplug it from air box, then close the end of the rubber pipe with an aftermarket air filter (small sizes usually priced about USD 3.75-7.5 per pcs) and tie it using cable tie to secure position, and close the hole on the air box using plastics or whatever u can use, theory based on 4 Stroke Performance Tuning book by A.Graham Bell, the saturated air on ur filter box from the engine blow by robs a little bit of hp, the reason they connect it to air filter box is because manufacturer must comply to government enviromental rule.
Race bikes use an oil catch tank to solve this engine blow by thing.
4. DONT over fill the oil, it will torture ur engine, optimum is at medium level (for Auto Clutch) and 95% position (for Hand/Manual Clutch).
5. Valve clearance
Performance Setting 0.10 (IN) - 0.13 (OUT)
Fuel efficient setting 0.12 (IN) - 0.15 (OUT)
6. Take off the choke if u rarely use it, helps a bit at high rpm.
7. Change the stock air filter to K&N, or use yellow foam side from old VEGA air filter element and modify it according to the size of stock air filter assy.
