150 CC DIASIL SPECIAL RECIPE PACKAGE :
150 cc KIT touched and TUNED on some parts by me (after Jan 1 st, 2009 purchases)
This CAM
+ VALVE SPRING
DYNO TEST spec :
Mikuni TM28 PJ 17,5 MJ 215
TDR Cone Air Filter + stock airbox
CLD Competition Pipe Header + NOB1 3BOLD silencer
Power Cam 5.8
Cryogenic Vixion Valve Spring
Head 22/19 Flowbench ported
Intake Kitaco
CDI TDR + Rextor
Final Gear 15-39
Gearbox Close Ratio :
1st - 33/13
2nd - 29/17
3rd - 23/17
4th - 23/21
FAG Hi Speed bearing
The kit are :
KIT UPDATE
PACKAGE I : 150 cc KIT
1. BASIC KIT
1. Piston ring set
2. Piston kit
3. Piston pin
4. Cyl block
5. Cyl gasket (lower)
6. Cyl head gasket
7. Water Pump O-ring
8.
STAGE 2 CAM
9. Circlip
10. Valve Spring
2. 150 cc TUNED UP KIT, BIG VALVE HEAD READY with modification at :
1. Modified piston
2. Shaved block
3.
SPECIAL POWER CAM 5.8 mm lift in replacement of the Stage 2 cam
4. Protec GROUND ULTIMATE coil
DYNO TEST RESULT FOR THE TUNED UP KIT with ABOVE TEST SPEC
DYNO TEST RESULT FOR THE TUNED UP KIT with STOCK CARB (BORED OUT to 23.5 mm), STOCK CDI and OPEN PIPE
Uploaded with
ImageShack.us
ALL ORIGINAL PARTS !!! contact me by email for pricing and shipping..
PACKAGE II : 180 CC 62 MM KIT (BLOCK, PISTON, PISTON WRIST PIN, PISTON RING SET)
Description : 62 mm forged piston, special steel bore, water jacket, piston rings, piston pin, gaskets
still use stock 14 mm conrod plug and ride
Special 62 mm forged piston with special cyl block.. no leak, no heat up issues
PIC HERE :
http://www.facebook.com/photo.php?pid=4221883&id=320505998430
DYNO TEST RESULT
Uploaded with
ImageShack.us
Instantly you'll get 150cc, 180 cc and superb acceleration...but the best thing is...
IT'S TROUBLE FREE AND POWER PROVEN YET STILL SAFE FOR DAILY AND LONG RIDE !!!
These came from a
long research which costs time, money and lot of effort..
NEW ! CRYO TREATMENT at small ADDITIONAL COST
What's to be treated ? Here they are :
1. Piston
2. Piston ring
3. Piston pen
4. Cyl block
and what is this CRYO TREATMENT actually ?
Read here :
http://www.metal-wear.com/
pm me for price..
Guaranteed to make u cry... gear two on my 86kg weight reaches 85 km /h FAST !!! EDIT : now my weight is 92 kgs...
So there's what are available for now..
I'm on Indonesia..
Pay by PayPal, wiretransfer or Western Union
contact pm or Yahoo messenger ID haentiara
Hi guys, just wanna share...
+3.5 mm stroke.. 65,7 mm stroke x 62 mm bore.. cryogenic treated parts..
Spec :
- Mikuni TM28 SUDCO Carburetor
- KITACO Intake Manifold
- SKF Cryo Treated C4 Crank Bearing
- Faito Auto Clutch Crankshaft
- TKRJ Conrod
- Semi Close Ratio (Full)
- 22/18 Big Valve Head
- Cryogenic Valve Spring
- 62 mm HiSpeed R type piston
- 5 mm block gasket
- TDR CDI
- NGK Laser Iridium CR9EIA-9
- 5.8 mm camshaft
- Temporarily Custom Modified Stock Exhaust Pipe due to Traffic Regulation
Piston type R modified..
Custom Engine mounting..
Layer cake gaskets
