Just do the poorsmans tps..hello mga sir i have a problem with my smx. ive changed my stock carburator to a keihin 28mm carb the problem is the tempreture lamp keeps turning on pls help......
that will be remove if you use BRT hyperband cdihello mga sir i have a problem with my smx. ive changed my stock carburator to a keihin 28mm carb the problem is the tempreture lamp keeps turning on pls help......
awts...stock bore with 30mm carb just buy another smaller carb...sirs, pwede mag tanong? nagkabit ako ng keihin 28mm rebore to 30mm, nagka issue dahil minsan hinda umaandar kasi na o over yung gas nya hindi maka start ang makina at yung consumption nya sa gas magastos, mga sirs ano pwede gawin para ma resolve ito? stock bore, aftermarket cams and clutch spring, stock cdi ang setup. salamat
30mm carb is too much for a 54mm bore even if you have after market cams. I suggest you stay on stock carb. You have an option to port it. You will solve fuel consumption issues and TPS problems.sirs, pwede mag tanong? nagkabit ako ng keihin 28mm rebore to 30mm, nagka issue dahil minsan hinda umaandar kasi na o over yung gas nya hindi maka start ang makina at yung consumption nya sa gas magastos, mga sirs ano pwede gawin para ma resolve ito? stock bore, aftermarket cams and clutch spring, stock cdi ang setup. salamat
sir thanks for the idea pero is it ok if the lamp keeps turning on ? does this affect the performance of the motorcycle
I suggest bro to change your Stock CDI to RCDI since you are using R valve spring and R cams,sirs, pwede mag tanong? nagkabit ako ng keihin 28mm rebore to 30mm, nagka issue dahil minsan hinda umaandar kasi na o over yung gas nya hindi maka start ang makina at yung consumption nya sa gas magastos, mga sirs ano pwede gawin para ma resolve ito? stock bore, aftermarket cams and clutch spring, stock cdi ang setup. salamat
