Yamaha t135 rectifier problem/any concerns
ronnelmarc_21
Mga papa,,nasubukan niyo na bang mag tanong sa yamaha kung magkano and rectifier para sa sniper natin??
Ive gone to one yamaha store wooow surprise ako sa presyo niya,...
aprrox 3,200 petot..
Ride safe
ronnelmarc_21
ang mahal masyado kaya gumawa nlan ako ng fullwave rectifier,,libre pa kc kinuha ko lang sa Company naminang Diodes na ginamit ko hehehhe,...
now my charging voltage is approx 15V in rev up,,,idle speed 12.8V.
ronnelmarc_21
very simple lang mga papi,,just a basic electronics circuit.
halfwave muna yan,,yan ang gamit ko for now since ginagawa ko pa ang fullwave rectifier para mas maganda ang soldering sa PCB at lagyan ng case for all weather use,...
four diodes doesnt only increase current capability but serve also as back-up once one diode is burn out.
BOMBIE
Diode
May mga available bridge type diode in one package na bro.., usually rated at 15 to 35 or more amperes.., ok na naman ito lahat kung sa motor battery charging lang...
Note:
Pero kung sira regulator mo, palitan mo nang recomended talaga na regulator. Ang rectifier ay iba sa regulator... Rectifier converts AC voltage to DC voltage, while the regulator helds the voltage constant regardless of the load and the voltage source. Sniper at high rpm produces more or less 18Vac, dangerous enough in overcharging the battery, unless a regulator is connected, which held the output voltage to approximately 13.8Vdc at any rpm level.... Just my thought.
iandasal
Boss pano pag mag shorted yung isang diode dyan?
