Jiou de Leon
i use cms valse bro. is it ok? and what do you mean "non magnetic" valves?hispeed v.spring is very stifffffff ^^ pare it with non-magnetic valves ^^
depnde sa pag set yan sir..kahit hispeed pwedeng mahina lng lagatik na parang vixion springmalakas ba lagitik ng CMS valve spring compare sa vixion? any cms valve spring user?
adding washers will put the stock springs in "more" tension and may make your stock valve springs prone to early coil bind ( you have shorten the compression travel of your spring.) rather than in the "normal" compression state. an upgrade is better than a backyard do it yourself and end up catastrophic engine damage. ouch!!is it possible to use washer on stock valve spring and valve to make it stiffer ?
which want in vixion??Vixion Valve Spring users here. We installed the Vixion springs on two snipers----2010 and MX. Two different set ups but one after effect....more silent engine with higher rev limit and speed per gear. Tried LHK aftermarket springs which were taller than stock but apparently couldn't handle the Turbo cam. It seemed then that stock was better. Vixion on both bikes now.
See the comparison of the LHK valve spring (left, longer and thinner) with the Vixion valve spring (right, slightly shorter but thicker).
2010
Faito Bore kit
Faito Turbo cam
Big Valve head
Kitti CDI
Namban Pipe set
2011 MX
thanks Trax (hehehe)
old cam from the 2010 (unknown)
stock head
stock CDI
stock exhaust
So far, so good. Hope this helps
Cheers!
