Red Light Indicator
Discussion in 'Engine' started by sigea, Feb 27, 2010.
  1. sigea
    sigea New Member
    Apr 4, 2009
    54
    Singapore
    Guys, recently i have a problem.. Firstly, when i put my key to on, the red light beside neutral will on, then off then will start blinking.. when i move off, at certain times its off but most of the time it stays on..
    I've read my manual, it states that its either something to do with the coolant OR there is a electrical wiring problem.. Can you guys help me out? and by the way im on stock CDI but when im using my rextor, this doesnt happen..
    Thanks!!
  3. BHER
    BHER Super Veteran
    Jan 23, 2010
    4,456
    460
    Dagupan City
    check the wiring bro. check also the water of the coolant. basically when the red lights on indicate of wiring failure or overheat
  4. jmoquin
    jmoquin Super Veteran
    Feb 3, 2009
    4,181
    26
    373
    urdaneta city pangasinan
    overheat....
  5. sigea
    sigea New Member
    Apr 4, 2009
    54
    Singapore
    will check the coolant, cant be overheat because the light is blinking even when i have not started the bike.. hmm any more opinions guys?
  6. doraemondizon
    doraemondizon Super Veteran
    Dec 14, 2008
    4,748
    11
    363
    valenzuela
  7. jmoquin
    Feb 3, 2009
    4,181
    26
    373
    from where pafs?
  8. express unlimited
    express unlimited Super Veteran
    Dec 9, 2009
    316
    341
    STA. MARIA, BULACAN
    same problem here since changed to bigger carb. doesnt happen with rextor but red light flashes when on stock cdi. no TPS anymore.
  9. reynard
    reynard Veteran
    Jul 27, 2008
    91
    106
    LLC, Cebu
    try to check the sockets connecting the cdi, might be loose contact.
  10. ronnelmarc_21
    ronnelmarc_21 Super Veteran
    Apr 27, 2009
    1,095
    361
    Bicutan, Paranaque City
    the temperature indicator will not turn "ON" if loose contact,,if it turn "ON" the G/W wire(Green/white) going to CDI is grounded,..theres a lil problem on your CDI at the temp sensor side,..as u can see on the wiring diagram,..its connected from Battery-main switch-temp indicator(#42)-CDI(thru G/W wire).
    I hope it will help u,..
  11. sigea
    sigea New Member
    Apr 4, 2009
    54
    Singapore
    alright thanks guys! will go check it out.. btw ronnelmarc_21, you had this situation before?
  12. wan6176
    wan6176 New Member
    Mar 2, 2010
    once u remove the tps from the carburettor the light will stay on nothing wrong with that..its normal n im using it.
  13. sigea
    sigea New Member
    Apr 4, 2009
    54
    Singapore
    so like its possible to remove the tps? whats the benefits?
  14. chuki2
    chuki2 New Member
    Mar 30, 2010
    69
    Sir..is easy to resolve that problem..
    Open ur coverset carb,then plug out ur TPS sensor..take air compressor,then shot at plug TPS..Then plug in back..try..
  15. naati
    naati Veteran
    Feb 21, 2010
    104
    131
    out of earth
    Maldives
    can u check the connections of the wiring. if there is water it may lead to problem like the wiring is grounded. and also its better if u change the coolant
  16. rich_havens
    rich_havens Super Veteran
    Oct 16, 2009
    5,311
    1,717
    Caloocan City - North
    your right sir...
    i expereince the same situation last sunday...
    i remove all the flairings... check my coolant and radiator... then i found out that there is a loose connection going to CDI...
  17. Bella
    Bella New Member
    May 2, 2019
    Hello guys, since im a girl and i read all your conversation and still cannot understand.. so if i go to workshop.. what i said to them? roughly how much i have to prepare to settle this problem? help me.. thank you..
