Racing Camshafts & Tips And Tricks
Discussion in 'Modification' started by xclickclickx, Sep 24, 2012.
  1. xclickclickx
    xclickclickx Veteran
    May 30, 2012
    237
    156
    161
    Vungtau
    Vietnam
    Hey Guys,
    Just thought I'd give you a couple of basic tips and tricks on camshafts
    and a very brief instructions.
    DISASSEMBLING (for newbies)
    Obviously If you follow the service manual things will be much more easier and smoother, But after striping all the plastics and draining the water and removing radiator. You will be getting prepared to take the rocker cover off and the water pump unit. (the water pump unit can come off with out disassembling the unit with only removing 3 bolts...top right bolt, top left, and bottom left bolts.)
    After that take the 2 bungs out of the side cover and turn it over to TDC mark the timing on the camshaft sprocket ..(even though there is timing marks already just mark your own anyway)
    Take out the cam sprocket carefully dont drop anything inside the engine ( to do that remove Cam chain Tensioner first ) then the camshaft (put a bolt in the camsahft and then pull on the bolt...it willl pop out easy)
    INSTALLING CAMSHAFT BEARING (for all)
    The best way i found was use my Fly-wheel Puller (about 30usd) i can remove and install bearings with this just be very careful not to leave any markings ...Heres a photo. Photo-0070.JPG
    INSTALLING CAMSHAFT (for all)
    All camshafts shall be greased up by something before there first start up.. a lot of people use grease but some greases don't dissolve so well so you could start our motor up and the grease COULD clog up oil galleries and end up resulting and severe engine failure.
    The best thing to use is Vaseline (the stuff single guys are hiding under there beds) it will dissolve well and will be enough for the engine start up until the oil gets to the cam:D
    Like so...
    Smear over both Lobes.
    INSTALLING (for newbies)
    Install the camshaft, camshaft sprocket (re-aligned with timing marks) take the bung off the camchain tensioner and turn the Flathead screw the tensioner should wind back in then fit this back on,
    time for the Valve clearances, each cam will be different but it should be close to 0.10 intake and 0.16-0.20 outlet (measurement in Metric..Just for those newbies:p ).
    after that it is time to put everything back together everything shouldn't be a problem then fill your water back up and start it up..
    Hope you enjoy your bike after this,
    depends on your riding style and bike setup which cam shafte you will like but heres a couple ive ried now.
    1.CMS camshaft High lift
    2.Uma Racing High lift
    3.Malossi Power cam
    4. Stock
    If you got any question feel free to ask.
  3. rpenera
    rpenera New Member
    Mar 17, 2012
    40
    12
    General Santos
    witch is better cam? cms, uma or malossi according to your experience?
  4. takomi
    takomi Super Veteran
    Sep 24, 2011
    760
    294
    novaliches quezon city
    same question ts?:D
  5. xclickclickx
    May 30, 2012
    237
    156
    161
    Vungtau
    Vietnam
    CMS beats them all,
    When i get back from Work in Australia ill buy a few other brands and see if any are better then CMS but so far CMS has been the best so far,
    gdeezzyy, kr.r_sniper and rpenera like this.
  6. rpenera
    rpenera New Member
    Mar 17, 2012
    40
    12
    General Santos
    Woow! lucky for me i bought CMS from admin! :D
  7. xclickclickx
    May 30, 2012
    237
    156
    161
    Vungtau
    Vietnam
    Yea should be sweet...I will let you know when i find a even better one if i do
  8. rowan
    rowan Super Veteran
    Apr 16, 2011
    1,788
    703
    upper valley, south cotabato
    :p
    safari13 likes this.
  9. rpenera
    rpenera New Member
    Mar 17, 2012
    40
    12
    General Santos
    Hi rowan i also have that cam, but i have never tried it yet. I know that the lift of cms and faito low cam is the same but maybe the duration is different.
    rowan if i used the low cam can you give me tips or suggestions regarding to the setup that i am going to make?
    -stock piston.
    -re-phase 1mm or 1.2mm
    -3mm valve pocket
    -Rvalve spring
    My concerns regarding the mods, valve will not kiss the piston if i used the lowcam to this kind of setup??
    suggestions please! eager to setup my bike. :help:
  10. rowan
    rowan Super Veteran
    Apr 16, 2011
    1,788
    703
  11. Ginger
    Ginger Super Veteran
    Oct 12, 2011
    1,174
    232
    Tuguegarao City Cagayan Valley
    sir sir rowan on stock bore 4mm piston pocket is it ok for cms cam and how can i silence the tiktik sound??? what would be the valve clearance?
  12. rpenera
    rpenera New Member
    Mar 17, 2012
    40
    12
    General Santos
    hehe, thanks for the advice.
  13. xclickclickx
    May 30, 2012
    237
    156
    161
    Vungtau
    Vietnam
    @rowan
    Your a negative bent for the God you think you are.:thumbsup:
    ill continue to experiment for fun, well you wank on about your AWESOMENESS much better parts all the time.....Eat my dust.
    @everyonebutrowan
    Got a mate with a flow bench now hes a 70yr old dutch mechanic and has been doing motocross and sportbike cylinder heads his whole life ! he has his own CNC and milling machine many other tools aswell , cant wait to return back home
    lilsai likes this.
  14. rowan
    rowan Super Veteran
    Apr 16, 2011
    1,788
    703
    :sleepy:
    JhayBoo and takomi like this.
  15. takomi
    Sep 24, 2011
    760
    294
    HEY GUYS!" Share your opinions not your emotions":D peace everyone wer all brothers here...:angel::hug:
    sorry off topic!!!
    milu likes this.
  16. rowan
    rowan Super Veteran
    Apr 16, 2011
    1,788
    703
  17. odie
    odie Super Veteran
    Aug 20, 2009
    492
    30
    353
    Kalinga,tabuk city
    ha ha cool guys sir rowan could the faito lowcam be paired with the cms vspring? will the metal wont deteriorate like the turbo of faito?is locam advance timing like cms that at stock setting is retard. pls. pm me if you dont want to share it here
  18. HKholic
    HKholic Member
    Oct 14, 2011
    192
    157
    58
    Buôn Ma Thuột, Dắk Lắk
    Vietnam
    I think he was referring to the CMS is the best of his personal inventory (Malossi, UMA, Vixion). Not the "best" cam that is available. We all know there are a lot of cams on the market. I think some of cam choice comes down to what the user wants for power. What my #1 choice of cam is, might not be what the next guy chooses. Everyone has a little different motor set-up and different riding styles. Part of what makes modding so fun, trying many different combinations to find what suits you. :hug:
    kuya_pepe, milu and suiluj like this.
  19. RX4439
    RX4439 New Member
    Dec 6, 2008
    46
    Gombak
    To Rowan - Chill bro. :)
    You use the Faito Lowcam Advance, can i know about the marking that u use when installing this Cam? Should be std marking or advance?
    Btw, What HKholic said was true, he (xclickclickx) refer to his own personal cam collector.
    P/S - There a lots of cam out there, CMS, YY Pang, MDS, Popeye, GT Racing, Ride It, ETC.
  20. rowan
    rowan Super Veteran
    Apr 16, 2011
    1,788
    703
  21. JamesCore
    JamesCore Super Veteran
    Sep 4, 2009
    1,990
    189
    Makati City
    Regrinded Cams is better. my 1st camprofile cams looks like the malossi power cams. Ive got a new regrinded cams better than my first.:)
