Not Staring W/o The Battery
kikaipitoy
I'm wondering why I cant start my MC without the battery, its like the whole MC is battery operated:):):) TIA
chie
You maybe right but I have some friends w/o battery but they can start their MC....inputs masters
bike start even w/o battery if your regulator is working but if your regulator/rectifier is busted that's the time your mc will not start w/o a battery, but if you have a battery it will stars, they do manufacturer as a double purpose.
also check your harness from regulator. :thumbsup:
JapSpeed
so meaning sira ang "regulator/rectifier" ni TS....
kikaipitoy
totally no battery or low bat lng? if wla talaga battery cguro hindi aandar yan.. not sure... AFAIK kahit low bat ang battery kinakargaan dn yn ng makina natin if umaandar... pero mga master na ang mka sagut technically talaga sa issue nto..
I stand corrected masters...low bat lang pala pero may battery so kahit kick start aandar pa rin MC nila....just like mine kahit lowbat pede ko sya kick start at aandar naman...pero pag wala as is disconnected ang battery kahit maghapon mo sya kick start di sya aandar....i tried once habang umaandar sya at idle speed (neutral) I removed the main fuse at yun namatay makina..is this a sign of bad regulator/rectifier? may nakapag sabi din sa akin na baka stator...UP
kikaipitoy
tinignan ko yung rectifier/regulator ko Ok naman sya in terms of outside appearance at wala ring kulapo...more inputs guys..TIA
jimpie
try mo ibalik stock CDI :) tapos lahat ng wiring socket ng harness mo alisin mo at gamitan ng compressor para bugahan para talsik lahat ng masasamang elements... tapos alisin mo yung spark -plug cup mo, testing mo kong may power kapag sinisipa or ginagamitan ng electric starter :) sana makatulong
kikaipitoy
UPDATE:
I think this is un-sual electrical problem, the first thing I noticed is that my one week old battery is drain with my HID already disconnected from the battery. So tried to kick start the engine and it appears to be Ok, check if it was charging the voltage when I rev it goes up to 12.5 to almost 13v. What I noticed is that due to low battery level the engine keeps on dying on me this is evident when I use the signal light and brake at the same time the engine dies but can be easily started using the kick start. Funny thing is when I apply my brake the red indicator light on the dash board also lights up...please take note that none of this happen if I have fresh charge battery...but eventually it will be drain after a few days knowing its charging I as stated above. Then what puzzles me is that I tried to remove the battery then kick start, engine wont start..but putting a dead battery then kick start it it will start but eventually die when you stop squeezing the throttle. Im thinking now that i have a defective STATOR or RECTIFIER...will bring it to my mechanic now for further diagnostics and will update you guys...this will be an informational scenario if solved. thank you
ESOJ de GUZMAN JR
yan ang sakit ng rcdi na brt dual band. pag lowbat hnd tlga ito gagana.. silipin mo ung ilalim sa may cdi at pg umiilaw ung blue means low battery at hnd tlga aandar ang mc mo ng maayos. as per experience lng po. kya for long ride always bring the stock cdi.
kikaipitoy
exactly sir may umiilaw nga na blue light so ibig sabihin pala nun lowbat and yes naka BRT dual band nga ako...now I know...galeng!! Salamat Sir:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
