Julio25
mamaw na sa set up sir ah..easy na lang siguro ang 150 kph..Update: Latest Setup
Tuneboss
62mm Semi-dome Type (piston works)
20/22 with Headworks
6.5 SpecV Cams
12 Holes Injector
32mm Throttle Body
JVT Hyper Clutch 5spring V2
Faito Crankshaft Bearing
Faito Coil
Iridium SP/CR8E/CPR8EA-9 (depends on purpose)
Motul Oil
Next Project:
Innovate Motorsports Wideband Sensor, Gauge & Data Logger
KOSO Drag Timer
Uma Oilpump
Racing Magneto
ang sarap naman ng set up na yan...hoooooo....Update: Latest Setup
Tuneboss
6.5 SpecV Cams
12 Holes Injector
32mm Throttle Body
Faito Coil
Motul Oil
Next Project:
KOSO Drag Timer
Uma Oilpump
Racing Magneto
