Mx King Tuneboss
JapSpeed
lakas sir, sakin mga 1.5km yata or 2km nag 156-157kph. next project ko sana is big valves pero need din pala throttle body and injector pa. hehe. magastos.
pwede throttle body lng muna.. my map dyan sa vixion na 62+cam+32 body throttle. pwede yn gamitin.. then sunod mo yng injector na 160cc. my map dn yn. last project mo si big valve. yn sana plan ko kaya lng ng R3 na ako.. after 2 to 3 years balak ko balikan si king. iba rn talaga pg underbone parang laruan na mimomodify mo. hehe..
bhaden
mga sir help po sa tuneboss ecu . incorrect password since nagpalit ng smartphone, hindi ko naman pinalitan ung default password nia.
mxking035
Update:
62mm semi-dome
CMS Cam T2
12holes injector
Stock throttle body
Faito Coil
Mas maganda mas mataas cc ng injector mas malamig sa makina kahit idle at city driving, mas malakas din arangkada at duluhan
mxking035
sir panu n nga e downlud ung tuneboss pro... pwd kaya s samsung jprime 7 anung brand ng62mm mo sir... d kaba ngpalit ng tensioner
Tensioner ko ay galing sa mio
Meron na available mag google ka lang "Tuneboss Manager Pro 2.01" kahit anong cp basta naka root, or sa tablet 7" mo e-install
Pitsbike chrome bore, 9months na
mxking035
bakit negative sir hnd positive ung aad mo s fuel
Dahil 12holes injector yan, 6holes ang stock, pang prepare ko narin sa 32mm throttlebody
Note: Ndi kaya ng "Staytuned" ang 12holes, pupugak yan kaya kilangan itono sya, 156km ko tinuno yan hehe
75-85*C lang ang init ng makina sa city driving kahit trapik po
mxking035
Update: Latest Setup
Tuneboss
62mm Semi-dome Type (piston works)
20/22 with Headworks
6.5 SpecV Cams
12 Holes Injector
32mm Throttle Body
JVT Hyper Clutch 5spring V2
Faito Crankshaft Bearing
Faito Coil
Iridium SP/CR8E/CPR8EA-9 (depends on purpose)
Motul Oil
Next Project:
Innovate Motorsports Wideband Sensor, Gauge & Data Logger
KOSO Drag Timer
Uma Oilpump
Racing Magneto
JapSpeed
Tuneboss
6.5 SpecV Cams
12 Holes Injector
32mm Throttle Body
Faito Coil
Motul Oil
Next Project:
KOSO Drag Timer
Uma Oilpump
Racing Magneto
lami-a oi!!! keep it up bro... :thumbsup::thumbsup::coffee::dance:
