NACZ
View attachment 32703 Crank case cover 1 & 2
Primary driven gear comp.
Clutch boss
Clutch plate 4pcs
Pressure plate 1
Clutch spring racing 4pcs
Bolt 4pcs
Spacer 1
Main axle, 4th, 3rd & 2nd gear
Flywheel
Gear primary drive 2
Spacer 2
Shift shaft assy
Crank 2
0977 464 2600
Clutch boss
Clutch plate 4pcs
Pressure plate 1
Bolt 4pcs
Spacer 1
Flywheel
Spacer 2
Shift shaft assy
Crank 2
0977 464 2600
