Lower your front shocks!
Discussion in 'Tips and Tricks' started by MioBikerBoyz, Apr 9, 2007.
  1. obetQ
    obetQ New Member
    Dec 1, 2007
    need advice plis..
    I did lower my stock front shocks for 40mm about 2 month ago..
    but the oil is faster to dry.. i've check there is no leaking arround the shock..
    What is goes wrong..?
  2. BigBird
    BigBird Super Veteran
    Feb 8, 2014
    389
    148
    San Fabian, Pangasinan
    Read mode:)
  3. Steve KH
    Steve KH New Member
    Jan 16, 2018
    Phnom Penh, Cambodia
    Others
    Obviously lowering the front end (usually by sliding the fork tubes up a bit higher in the triple clamps) does affect chassis geometry. Also reduces ground clearance. Re handling and stability, the moto will have sharper rake angle and less trail. At least in theory this reduces stability but steering should feel sharper and allows the bike to turn more aggressively, up to the limit of front tire traction at least.
    Personally, the T150 steering geometry seems way quick enough anyway, so I won't mess with that for now. What this moto needs (badly) is stiffer/stronger front suspension. Rear monoshock is robust but front end is shockingly inadequate! Spindly little 28mm tubes with just over 100mm travel, feeble springing and feels like zero damping... With a 90kg pilot it is crunching, clonking and bottoming out on even the most minor ripples in the tarmac - and Phnom Penh streets have plenty of tougher challenges.
    So am contemplating air forks conversion and heavier fork oil (coz those mods are cheap and easy!). Calculator says 2-3 bar (200 - 300 kPa) air pressure should sort it out, with 20 wt oil replacing 10wt OEM spec. Actually maybe there isn't any fork oil at all right now, it feels that bad!
    Has anyone done this, or anything similar? Any tips, ideas and experience successful or otherwise welcome.
    2016 Exciter T150 (100% stock so far)
  4. man_sate
    man_sate Super Veteran
    Apr 8, 2010
    1,006
    176
    Kajang
    Good idea and keep posted if you start doing it. Im interested.
    Never tried this because i'm using good fork oil which is motul. I have been using it for long time and there is 3 type of them soft, medium and hard. Hard is thicker oil and maybe it's to hard for me since im lowered my fork to 2". For now only use medium type and adding 2 bolt size 17mm inside fork tube.
