LOW CAM ADVANCED
Discussion in 'Modification' started by clydelisboa, Feb 2, 2011.
  1. clydelisboa
    clydelisboa New Member
    Apr 15, 2009
    72
    any one care to explain technically this type of cam and its difference to other racing cams (eg: stage 1, stage 2, high lift cams) TIA
    [​IMG]
    plAy_siT@135e$ and rem like this.
  3. rem
    rem Super Veteran
    Apr 8, 2011
    718
    112
    edwards tboli south cotabato
    im curently using this type of cam. we tried to follow the instructions at first but it makes a lot of noise. we re adjusted the tyming to the standard settings the noise disapeares but on the instructions it says that u need to pocket the piston to achiev max results havent tried packeting my pistons yet, hope someone hu had tried share some infos.. following this thread
  4. romkazoo
    romkazoo Super Veteran
    Aug 6, 2009
    909
    16
    346
    Davao City
    this low cam advance is quite expensive than S4 evo right?
  5. romkazoo
    Aug 6, 2009
    909
    16
    346
    Davao City
    REM, does all faito camshaft has unnecessary noise? or is that normal for all after market cams?
  6. traxxas-modifier
    traxxas-modifier Super LOLO Staff Member
    Dec 17, 2006
    8,047
    4,215
    438
    gensan
    the faito low cam advanced has instruction that you need to advanced the timing mark to letter H
    instead of the I , if you do the advanced you need to pocket your piston else noise will occur
    which means the valve and piston is kissing each other.
    BigBird, R135LC, docgabby and 3 others like this.
  7. romkazoo
    Aug 6, 2009
    909
    16
    346
    Davao City
    sir traxx if theres noise it means there's collision between valve and piston? I thought its normal for an aftermarket cams.
  8. 6sic6
    6sic6 Super Veteran
    Nov 16, 2009
    2,083
    66
    376
    makati
    very infomative thanks admin!!!
  9. traxxas-modifier
    Dec 17, 2006
    8,047
    4,215
    438
    gensan
    theres a big difference
    between tik tik tik tik sound on racing cam
    and TOK TOK TOK TOK on kissing valves and piston :D
  10. rspayumo
    rspayumo Super Veteran
    Dec 17, 2008
    898
    91
    353
    Bulacan
    I have also heard that the Tik Tik Tik sound may come from the stiffness of our
    Valve Springs.
  11. technician
    technician New Member
    Apr 8, 2011
    89
    4
    Check for BTD and tappet. Too tight tappet adjust might cause a collision between the piston and the valves.
  12. technician
    Apr 8, 2011
    89
    4
    I believe this is a stage 1 low profile cam. It has a lower lift than a faito cams. Lower cams are more silent than a high lift cams. But this cam doesn't seem to have a good accelaration performance base on the cam angles.
  13. romkazoo
    Aug 6, 2009
    909
    16
    346
    Davao City
    so tik tik tik is normal... hehe thanks!
    milu likes this.
  14. rem
    rem Super Veteran
    Apr 8, 2011
    718
    112
    im planing to pocket my piston nxt month ill update you guys once im done
  15. rem
    rem Super Veteran
    Apr 8, 2011
    718
    112
    @technician: any advice on what valve clearance should we use sir?
  16. Jval Zkie
    Jval Zkie Super Veteran
    Dec 1, 2007
    4,896
    890
    Upper Valley Area, South Cotabato
    So it's better to hear TIK TIK TIK than TOK TOK TOK :D
    @rems, bro. what is your engine set up?
  17. Noah501
    Noah501 Super Veteran
    Apr 8, 2011
    556
    51
    Cagayan de Oro City
    How much do cams costs?how much speed does it add? Newboe here.:)
  18. rem
    rem Super Veteran
    Apr 8, 2011
    718
    112
    @jval rcam port/polish (head/carb/manifold) rcdi.
    y bro?
  19. technician
    Apr 8, 2011
    89
    4
    sir, valve clearance depends on the lift of your camshaft. You have re adjust over and over till you get the lowest possible output for better performance. try starting on 9-13, 10-15, 13-18. make sure your valves isn't hitting your piston or else it's another heck of a problem...
  20. technician
    Apr 8, 2011
    89
    4
    again sir it depends on the type of camshaft, LHK cams is 2000, Kawahara 2500, Uma is 3000, faito is 3000, yypang is 7000 all probability. Its an absolute +10kph-30kph depends on your tune up sir. Higher lift cams has slower response depends on the angle...
  21. technician
    Apr 8, 2011
    89
    4
    TOK TOK TOK and TAK TAK TAK means check your piston for a sign of collision. Tik tik tik is good for racing racing hehe
    milu likes this.
