allanboy_g
up natin mga paps..
sana may magfeedback at magshare pa
UMA 28mm user ako paps raider manifold gamit ko sakto lang naman di siya tatama sa chasis.. FOR me suited sayo yung KEIHIN PE 28 for daily use and madali siyang itono piliin mo yung thailand walang adjuster sa needle yun.ayon sa Rumor paps..pag daw ung raider na manifold ang gamit sa Uma..magtatabas pa daw sa chassis?..
dapat daw uma na manifold din..Tama po ba ung tsismis sir?..salamat sa reply paps..
ano mj at pj mo paps?..current set up?..uma 28mm na din kinuha ko with uma manifold..UMA 28mm user ako paps raider manifold gamit ko sakto lang naman di siya tatama sa chasis.. FOR me suited sayo yung KEIHIN PE 28 for daily use and madali siyang itono piliin mo yung thailand walang adjuster sa needle yun.
hellow Moderator..please Move my Thread to Counrty specific Forum or any other forum that can we Speak Freely..Reminder: YOU ARE ON ENGLISH SPEAKING SECTION, Please post in ENGLISH!
no problem idol, ...ride safe!hellow Moderator..please Move my Thread to Counrty specific Forum or any other forum that can we Speak Freely..
sorry for the TAGALOG ..
Very thanks..
ahh you mean flatslide ang mga uma?
thanks din idol...peace..no problem idol, ...ride safe!
moving this into phil section thread..
hahaha....likewise bro!thanks din idol...peace..
flatslide ang UMAahh you mean flatslide ang mga uma?
--try nyo poh sir 115 and 42..badoodle
paps, ano po ma-recommend mo jettings ng UMA 32mm?
ito yung set up ko:
60mm bore
PNP
19/22 big valves
CMS cams, valve spring
tnx po!
yup sir same lng ng jetting ng OKO..cgro sir yng main jetting lng muna palitan moh sir..yng sah gitna bah..sana makatulongcopy po papz. try nmin..same jettings lng sa oko db? ty
sir sakin po kaya anu magandang carb?
my setup is vixion bore, s4 evo cams, vixion valve spring, brt dual band cdi.
sa current setting ko, vixion bore, s4 evo cams, vixion valve springs, at brt..
mj-115
pj-37...
black ang Sp..mag baba ba ko ng Pj idol?..35 maybe?..
maganda syang humatak, walang problema sa low-high rpm..
salamat idol..
