Just incase you want to extend outward your engine sprocket for whatever reasons,
here is the trick how you will do it.
I need this mods since im using 150/70 tire on my sniper and the chain is touching
the side of the tire. So to fix it, move outward the engine sprocket.
-I use 2 engine sprocket.
-In one sprocket, i remove the teeth
-while in the other sprocket, i bore 2.5mm deep and 30mm wide so that the lock ring will embed inside the sprocket.
Here the toothless sprocket is inserted first, Then sandwiched the sprocket lock nut by the new sprocket
Notice the sprocket, its almost on the edged of the transmission shaft.
Hope that helps
FINAL OUTLOOK
it moves the sprocket outward by 7mm
Hope that helps
FINAL OUTLOOK
