Help with idle speed
Discussion in 'Yamaha Vixion FZ150i' started by amorales_mx, Feb 4, 2009.
  1. amorales_mx
    amorales_mx New Member
    Jan 29, 2009
    13
    México
    Hi, my name is Andrés from México city.
    I have a F150-VIXION and I like to know the proceed to adjust the idle speed, I read something about T135 but the throttle body is different, I hope you can help me.
    I have a question, when the throttle is closed from mid-to-high rpm.
    I hear some explosion (backfire) but they are very loud, and I dont know if it is normal or how I can fixed.
    Thanks
  3. traxxas-modifier
    traxxas-modifier Super LOLO Staff Member
    Dec 17, 2006
    8,047
    4,215
    438
    gensan
    hi amorales
    welcome to yamahat135
    can you post picture of your bike?
  4. amorales_mx
    Jan 29, 2009
    13
    México
    Here they are.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  5. jay.e.l
    jay.e.l Super Veteran
    May 5, 2008
    630
    343
    Rizal, Antipolo City Originally from Magsingal,Ilo
    nice bike
  6. traxxas-modifier
    Dec 17, 2006
    8,047
    4,215
    438
    gensan
    bro morales
    youve got a nice bike!
    seems that sticker is for mexico only..
    can you confirm that your vixion is also EFI (electronic fuel injection)
    just like the vixion of indonesia and FX150i of malaysia?
  7. amorales_mx
    Jan 29, 2009
    13
    México
    Hi, yes is EFI, and all specs are the same.
  8. traxxas-modifier
    Dec 17, 2006
    8,047
    4,215
    438
    gensan
    hmmm i will check the service manual here...
    maybe haen can help also...
    or bro joel...
  9. eboitot
    eboitot Super Veteran
    Jul 15, 2008
    1,497
    363
    Bulacan
    nice bike bro :D
  10. traxxas-modifier
    Dec 17, 2006
    8,047
    4,215
    438
    gensan
    bro amorales
    i check the manual
    to change idle speed,
    turn the idle screw on the throttle body
  11. amorales_mx
    Jan 29, 2009
    13
    México
    Thank you very much bro, I just adjusted the idle speed and it is great.
  12. traxxas-modifier
    Dec 17, 2006
    8,047
    4,215
    438
    gensan
    have you tried changing air filter bro amorales?
  13. CarroTT
    CarroTT Super Veteran
    Mar 22, 2007
    592
    343
    yo my brader from mexico :p
    urs have a nice scheme
    in my country, oni have red, grey, greyish green n black
    very dull colors
  14. amorales_mx
    Jan 29, 2009
    13
    México
    Hi bro, yes the air filter is new, now the idle speed is ok at 1400 rpm but the explosion on exhaust (back fire) are equal, I look for leaks and I found a little and perfect hole on the bottom of exaust, when I seal it, the back fire are less frecuent but continues. I read about backfiring can occur in engines that are running lean where the air-fuel mixture has insufficient fuel.
    Exist any way to adjust the air-fuel ratio on this bike (EFI)
    PD- I'm sorry about my english.
  15. CarroTT
    Mar 22, 2007
    592
    343
    the problem is most probably from a leaked exhaust
    y do u have a hole there anyway ?
    hit a curb somewhere ?
    usually on EFI, u dun reli nid to adjust the fuelling coz its oledi self adjusting
  16. mckoyzki
    mckoyzki New Member
    Mar 11, 2009
    cool and nice bike :shock:
  17. amorales_mx
    Jan 29, 2009
    13
    México
    No, I did not hit any thing, I spoke with dealer and told me that this hole is to drain water and told me some thing about adjust CO parameters with scanner, but I don't trust them.
    What do you think?
  18. imyz
    imyz New Member
    Jan 30, 2008
    4
    penang
    PD- I'm sorry about my english.[/quote:d0u012ow]
    hello amorales... nice bike... blue is my favorite.. 8)
    insufficient fuel is 1 of the problem.. my suggest is, try to adjust the oil lean (CO), where, the standard for this bike is 0.. maybe u can set up to +3 or +4.. range for this CO is, between -30 to +30.. but.... this CO can be set only by special tools, call, FID. u can try ask from ur dealer bike about this tools. i'm sure they can setting the CO for u.
    1 more thing, maybe ur 'air cut off valve' didn't function properly... this valve should be close during suciden deceleration (the throtle valve suddenly close), mostly, at high rem., in order to prevent after burning, as what happen to ur bike. but this is too far, i think, compare to ur new bike..
    another way, try check back the plug, maybe not really tight, or u can just change the new one...
  19. Guest
    Guest Guest
    u cant try to close the Air Induction System..
    location is above the silinder head...
  20. amorales_mx
    Jan 29, 2009
    13
    México
    thank you very much for the answers. Do you know what parameters modify when you adjust the CO?
  21. CarroTT
    Mar 22, 2007
    592
    343
    its just adjusting the fuelling according to the sensor that senses the combustion gases
    well bro, if the bike didnt pop before when ur bike was newer, its most probably nothing to do with the fuelling
    that hole that lets water out is common on this kind of muffler, its always at the lowest point of the exhaust to the ground
    i still say there is still leaks in ur exhaust
    i always say, try to fix the most common n cheapest fixes first
    changing an exhaust gasket is darn cheap, and its the most common cause that causes pops in the exhaust
    really no harm at all doing it
    rather than to start tinkering blindly tat wud cost u a lot of money n end up still with the same problem.
