Help! Valve Problem
Discussion in 'Modification' started by fLip, Sep 18, 2016.
  1. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    :help:mga paps, ask lng bkt kya pudpod n kgd valve ko 2weeks lng.. standard size faito, hi speed valve spring, 5.8 lift ng cams.
    tia.:thumbsup:
  3. Dropper
    Dropper Veteran
    Oct 8, 2013
    276
    90
    146
    Cordoba, Cebu
    maybe your cam lift might too high :rolleyes:
    fLip likes this.
  4. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    5.8 sir
  5. snipermxmalayaklan
    snipermxmalayaklan Super Veteran
    Oct 4, 2013
    440
    349
    Aklan
    based on my experience Sir, this could as well make your valve blunt fast. open carb, loose valve guide, not flat valve spring from end to end, not seated properly , too stiff V.S. that's just my observation Sir, lets wait for masters' help.
    fLip likes this.
  6. JapSpeed
    JapSpeed Super Veteran
    Dec 23, 2013
    2,042
    954
    Bacolod City
    hi speed valve springs are so stiff. install shim and retainer for your valve tip protection.. based on my experience too..
    jangbest and fLip like this.
  7. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    thanks mga paps, planing to install shims:)
    JapSpeed likes this.
  8. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    one more thing mga papz, can i use the stock vs for intake only instead of hi speed vs.. will it make any harm on my head?
    thanks again in advance
  9. snipermxmalayaklan
    Oct 4, 2013
    440
    349
    Aklan
    are
    are you on RCDI Sir? if yes, it's a must to put some stiffer valve there. in/out.
  10. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    QUOTE="snipermxmalayaklan, post: 654587, member: 17696"]are
    are you on RCDI Sir? if yes, it's a must to put some stiffer valve there. in/out.[/QUOTE]
    m
    not yet sir
  11. snipermxmalayaklan
    Oct 4, 2013
    440
    349
    Aklan
    m
    not yet sir[/QUOTE]
    if not yet Sir, then there is no need to replace to stiffer valve spring since as far a i know the only purpose or RCDI is to increase your RPM limit. With stock CDI your RPM will be restricted to a safe capability of your valve spring.
    fLip and JapSpeed like this.
  12. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    if not yet Sir, then there is no need to replace to stiffer valve spring since as far a i know the only purpose or RCDI is to increase your RPM limit. With stock CDI your RPM will be restricted to a safe capability of your valve spring.[/QUOTE]
    thanks sir :)
  13. docgabby
    docgabby Super Veteran
    Jun 11, 2007
    949
    461
    legaspi city
    change stock tapet screw to Honda cb110 or Honda wave dash (same parts number) tapet screw. more surface area for your tapet screw to contact valve tip. design similar to mx king
    jangbest, fLip and JapSpeed like this.
  14. docgabby
    Jun 11, 2007
    949
    461
    legaspi city
  15. docgabby
    Jun 11, 2007
    949
    461
    legaspi city
    [​IMG]
    that is the tapet screw of the Honda cb110 inserted from below on the stock rocker arm of sniper. more surface area to contact valve tip
  16. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    thank you po sir
    UOTE="docgabby, post: 654673, member: 393"][​IMG]
    that is the tapet screw of the Honda cb110 inserted from below on the stock rocker arm of sniper. more surface area to contact valve tip[/QUOTE]
  17. docgabby
    Jun 11, 2007
    949
    461
    legaspi city
    [/QUOTE]
    the tapet screw of the Honda cb110 is easier to find and much cheaper. compared to the mx king which takes at least a minimum of three months to order. I think Yamaha made changes to tapet screw design with mx king since it was becoming a common problem of the old design..mushroom valve tip
    fLip likes this.
  18. docgabby
    Jun 11, 2007
    949
    461
    legaspi city
    I have used shims from the Suzuki raider and even used their valve retainer. but I had incidences were the shim jumped out (you have to be meticulous with your valve clearance). you have to sand the shim to its thinnest so its deep within the retainer. the valve tip to valve lock distance is much wider for the sniper. be cautious of this if you want to go shim. :thumbsup::coffee::eek:
  19. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    thank you sir
  20. docgabby
    Jun 11, 2007
    949
    461
    legaspi city
    based on the parts catalog of the mx king they have changed to a wider tip tapet
    [​IMG]
  21. fLip
    fLip New Member
    Jan 11, 2015
    24
    9
    cavite
    is it possible to use mx king taet screw?
