if were to change the plug cable, normally it comes with cable+coil and do we to change that too.Frozen Fire said:iridium will only give you best result if you change your spark cable too, because it's useless if you want a better firing with a better plug but your cable stay in high resistance
good firing means effective fuel consumption, will give you more mileage
any good brand racing , cable and coils for recomandationFrozen Fire said:carb tuning is a must, even at schedule maintenance
I once read a comparison between matching racing plug, racing plug cable, and racing coil with stocks.
The best combi of course is all part racing.
The second is stock coil+racing cable+stock plug, cause stock coil and plug still able to work even better if you reduce the cable resistance.
So the most significant, the first step you should change is the cable, then the plug, last is the coil.
looks like a magnifier, it going to be costly is it?goff_d_p said:looks like a pipe for smoken a joint!!
Thats a good idea, for more effiecient print out this photos in colour for quick and easy reference!!!!!!!! Probally in 2 or 1 pages you're able to squezze all the photosFrozen Fire said:Looks like i'm gonna upload my laptop photo and title it as a special tool to check plug![]()
