H2O ON RADIATOR
johzz
AYOS LANG BA NA TUBIG LANG TEMPORARY LAMAN NG RADIATOR KO?
WALA KASI MABILHAN NG COOLANT DITO..
Rjloks
ayaw pa maniwala....
kalungkot naman. hahahaha
use it pwede yan. basta check mo lng lagi baka ma ubos na eh tumakbo pa ng malayo. shell meron coolant ace hard ware meron. DIY shop meron din.
Rjloks
actually kahit ano pwedeng ilagay. kaya lng distilled para hnd nag kakalawang. para malinis lagi ang tubig na nag papalamig sa block.
johzz
cnung nd naniniwala :twisted: :twisted: :twisted:
ty mga papa.
madali maubos pag tubig?
tama?
Rjloks
hnd naman sa madaling ma ubos. try to think na nag papakulo ka ng tubig. once na na iwan mong naka salang diba na uubos din. ganun in yun kasi ma init ang block ng motor.
pero parag ganun na nga. hahaha basta check mo lng. hnd naman mahirap yun.
johzz
CGE PAPA
summary: OK LANG TUBIG SA RADIATOR, BASTA IMPT. CHECK CHECK ang LABEL SA CONTAINER.
johzz
haha, wala paps. cooling system lang to :)
alisin mo radiator, weight reduction yan. bibilis MC mo.
haha joke
sniperyaz
ok lang naman H2O pero ang daming disadvantages like madaling kalawanganin yung radiator, bilis maubos, mabilis magbara yung dinadaanan nito sa makina due to kalawang...
sniper135lc
ok lang distilled water for temporary use sa radiator cooling system ng t135 di tulad ng coolant mabilis lumamig ang engine pag distilled water kasi mabilis mag rise yung temperature di gaya ng coolant. safe pa rin naman gamitin ang distilled pero dapat monthly ang palit di gaya ng coolant na every 3 years or 20k km which ever comes first ika nga sa manual. di po kinakalawang ang radiator ng t135 kasi aluminum po yan fyi.
i use petron radiator coolant its cheaper :)
in the service manual it says that use distilled water (which i personally use mineral water/distilled drinking water)
i think the reason for this is tap faucet water tends to have lots of residues deposits and chemicals which forms
a gummy or solid deposits when its heated.
try to check the inside of your kettle you will see lots of solid deposits there...
the same thing with our radiator, if you use tap water, as time goes by it forms a solid deposit which will clogged up some of the radiator small passages.
though it will take time to form a solid deposit in your radiator,
its better to use mineral dringking water or distilled drinking water to our radiator to avoid the said problem in the long run.
just remember, what you want to your body... apply it also to your engine :) hehehe
Rjet100 said:
hehehe bakit sa mga dyip tubig lang din gamit ^^ pero mas maganda pa din talaga coolant
kasi mahal at magastos ang distilled mineral drinking water P35/gallon.
jeepney drivers hinde kayang gumastos sa mga ganyan.
practical reason...
actually pwede naman talaga tubig gripo gamitin mo..
P15 mineral water or libre tubig gripo...
nasa may ari na talaga kung ano gusto nya depende sa kanyang budget.
