F/s Racing Or Oem Parts & Accessories For Sniper/x-1r/snipermx (online Shop) By Kr.r_sniper
kr.r_sniper
Motorcycle Parts & Accessories (OEM) ONLINE SHOP (ft. Racing Parts for LC135/Spark135/135LC/Sniper/SniperMX/X-1R/MX Jupiter/Jupiter MX)
Cash Basis Only
By Order Basis 1-2days
Payment thru BDO Bank or Any Money Transfer Services
Can ship to any part of the Philippines cia LBC/AP Cargo
GCash & Smart Money are not Accepted**
Freight/Shipping Charges excluded (Shoulder by the client)
Prices are subject to change without prior notice
Contact person Kent Rainier a.k.a Kr.R_sniper MCP/UBP/T135
Facebook account http://www.facebook.com/KR.RSNIPER
Contact # 09286144241/09151433479/09321811066
Racing Parts are no warranty at your own risk**
NOTE:
NO BOGUS BUYER & LOW BALLERS...
PM me For Orders or Inquiry...
PAYMENT thru Bank
BDO
Account Name: Kent Rainier C. Buenaventura
Account # 001490138852 "Kabayan Savings Account"
Thank you BDO you find ways.
______________________________________________________
BPI
Account # 4359107094 "Savings Account"
Thank you BPI you make it easy.
___________________________________________________________
Proof of Shipping & Transactions
For Feedback's & Ratings or Suggestion you can click the links below...
http://www.yamahat135.com/threads/kr-r_sniper-customer-feedback-ratings.6829/
kr.r_sniper
Vi-xion 57mm Bore kit OEM (DiaSil)
Racingboy Rearset for Sniper/SniperMX/R150
UMA By pass w/Breather hose for Honda & Yamaha MC Models (REPLACE YOUR DIPSTICK)
Faito Connecting Rod Kit (Stock size/length)
Mikuni VM26 Carburetor
Faito 4mm Block Gasket (60mm)
Faito Engine bearing set (Crankshaft & Transmission Bearing)
UMA Timing Gear Assy
Vi-xion Valve Spring (OEM)
Pro-tec Ignition Coil Car-speed Edition
Pro-tec Ultimate Ignition Coil with Ground strap
CRG Clutch spring (Stiffer Clutch Spring "Racing")
SSS Chain & Sprocket set 415size
RAD Cone type Air filter 360 degrees
IKK Clutch gear 22T-72T
R6 Tail lights 06-09 version (Diamond)
TK Valves Spring (Made in Japan)
kr.r_sniper
Faito Transmission Gear Box (Racing Tranny)
Hispeed Exhaust System stg2 (Open Specs)
TKRJ Connecting Rod set "Stock size" (Made in Japan)
Faito Plug wire (High tension wire)
Thermal Wrapped (90/meter)
Earl's Braided hose
Stainless Screw (Replacement for Fairings screw & Body bolt)
SYS 6 spring Clutch Housing (Racing)
BRT Powermax CDI
Faito Clutch Lining Thunder
UMA 62mm Chrome bore ceramic + Forged piston
Racingboy Rear Brake system
IKK stage 2 Camshaft w/high speed bearing
AHM Gold Round type series (Bolt)
Stainless Oil Filter 300php
Faito 19/22 Valve set Titanium Series
Faito Ignition Coil with ground strap Model 7400
Yoshimura Exhaust system 1st gen Full Stainless
Racingboy Fork Stabilizer V2 & V3
kr.r_sniper
CMS Stg2 Camshaft 5.8mm lift
Racingboy Cruise Balancer (Throttle Lock)
APPI Valve Springs Malaysian Cubprix Specs
LHK 19/22 Head with Raider Valves
Faito Clutch lining Swift-Z
X-1R Hub set OEM
CMS 19/22 Valve set
Fag C3 High speed Bearing (Transmission & Crankshaft)
Sniper MX Manifold
Faito Turbo Camshaft stg2
UMA High Flow oil pump
LHK Stainless Duo cap
Racingboy Alloy pedal with rubber (FOLDED)
UMA 62mm Piston Kit
KOSO TT Style Side mirror
Racingboy Monoshock
UMA Clutch spring (Racing)
R6 Tail Lights 03-06
Faito Lightweight Valve set (Stock size)
UMA Titanium Valve Retainer
kr.r_sniper
X-1R Rearset OEM
AP Quick Throttle Yamaha Model
Racingboy 8spokes Mags
Faito Mini HID Bulb (Peanut bulb replacement)
CMS 4th gear
Special Profile Stage 2 camshaft 5.8mm lift with High speed bearing (Made in Indonesia)
Kawahara K1 Stage 1 cams
Faito Gear set 1st,2nd,4th gear
Faito Clutch spring Zero
Kawahara K2 Stage 2 cams 5.8mm lift
Racingboy Handle Grip V.05
Keihin PE28 OEM Honda Thailand
YYpang Valve Springs
Customize Tappet Screw (LONG)
AHM M1 Series Standard (LONG)
AHM M1 Series GP (Short/Open Specs)
kr.r_sniper
Kinbar Disc Lock Alarm
Faito Steering Cone
Faito Top Overhaul Gasket (60mm)
Gas Tank Cover
Racingboy Single Rearset for SMX (Racing Used)
Racingboy Master Pump Assembly
Polyquad Cylinder Head for lc135 Intake 23/21 and Exhaust 18/19
Big Valve Cylinder Head for LC135 20/23
