Yamaha V-Ixion Bore up Kit 150cc
Discussion in 'Modification' started by MagaslawsiIslaw, Feb 3, 2009.
  1. haen
    haen Super Veteran
    Mar 29, 2007
    956
    78
    353
    BANDUNG, WEST JAVA
    Indonesia
    the comp rate after changing with vixion block or tuned from me is still within standards.. on service manual minimum is 5.3 kPa, normal at 6 kPa and max at 6.3 kPa.. i've checked it with compression tester and the result is : 6 kPa.. great, isn't it ? will post the pics to prove it..
  2. cuplis
    cuplis New Member
    Jan 17, 2009
    @ Haen : CMIIW, in t135 service manual, it's said that standar compression was 5,6 kg/cm2, and max 6,3 kg/cm2.
    after put the vixion kit (short block & camshaft) and checked with compression tester as you said, here the result :
    [​IMG]
    that is me & my mx
    [​IMG]
    [​IMG]
    [​IMG]
    banzai compression tester show 6 kg/cm2 for the compression, above the standart but not over the max...
    so in my opinion still safe for daily riding
    enjoy...
  3. haen
    haen Super Veteran
    Mar 29, 2007
    956
    78
    353
    BANDUNG, WEST JAVA
    Indonesia
    agreed cuplis.. urs is from stock piston and block.. my 600 kPa results came from my tuned piston, block and stage 2 camshaft.. would post my pics later..
  4. jay.e.l
    jay.e.l Super Veteran
    May 5, 2008
    630
    343
    Rizal, Antipolo City Originally from Magsingal,Ilo
    nice,
  5. King.Leoric
    King.Leoric Super Veteran
    Nov 1, 2008
    579
    343
    Meycauayan, Bulacan
    bro haen, this fuel consumpstion and top speed is stock carb? or rejetted stock carb? size of jettings?
  6. jay.e.l
    May 5, 2008
    630
    343
    is the vixion 150cc plug and play
    do you have to do any other modifications
    cant we get a 170cc Kit??
    Malossi 63mm Big Bore Kit
  7. haen
    haen Super Veteran
    Mar 29, 2007
    956
    78
    353
    BANDUNG, WEST JAVA
    Indonesia
    ok this is my results, i won't take anyone's pics.. don't worry :)
    [​IMG]
    @cuplis : ok i am a bit forgot.. lol.. it must be my age.. minimum comp is 490 kPa (4,9 kg/cm3, 70 psi), standard is 560 kPa (5,6 kg/cm3, 80 psi), maximum 630 (6,3 kg/cm3, 90 psi) all at 500 rpm
    @king : as for stock carb no jetting required as long as u don't change anything like comp ratio / cam.. top speed for stock carb and stock vixion block about 125 - 130 kmh here depending on rider weight, tire size, and stock sprocket..
    @jay e.l : u can try those, but it's better to enlarge ur crankcase hole.. i am satisfied with my 23 hp results.. except those kits can provide much power with increased durability.. isn't that for Yamaha Majesty ?
    as for Vixion bore up it's plug and ride kit..
    rotsen likes this.
  8. hearthrob16
    hearthrob16 Super Veteran
    Apr 8, 2009
    3,662
    45
    373
    Greetings! I just want to ask guys, how much is the vixion kit and where to buy it? Is it compatible to yamaha x1r?
  9. sjeevi30
    sjeevi30 New Member
    Apr 1, 2009
    23
    jz wana ask opinion u ppl ere... m planing on tis vixion kit upgrade... as i always go on long distance trips.. i need suggestions on what exhaust and carby i should use?? or is it better for me to just rejet my stock carby and stick to the stock exhaust... plz help...
  10. chiglai
    chiglai Super Veteran
    Sep 9, 2007
    1,435
    100
    373
    CDOC
    someone is really trying to mess up the minds of those who can afford and wants to upgrade to vixion.. others just envy and has a lot of negative feedbacks to say about it...
    check this out.. i was on vixion kit when we travelled... what the heck i cant even cruise on 80kph cause traxxas and i was pushing out t135 to the limits...
    http://www.motorcyclephilippines.com/fo ... loban+ride
    im sorry other post was on tagalog
    cut things short we ran almost 700kms in less than 24hours..
    no signs of weakness for the vixion kit
  11. chiglai
    Sep 9, 2007
    1,435
    100
    373
    CDOC
    oh i forgot we have a ride comming up next week two of us will be on vixion kit, one with stock carb and the other one will on yoshi carb.... i must say its a brutal ride.. 4 days that is...
    we really do trust our vixion kits!
    http://www.yamahat135.com/forum/viewtop ... &start=180
    i really wont join this ride if im not that confident about vixion kits...
    Mac-Mac likes this.
  12. sjeevi30
    sjeevi30 New Member
    Apr 1, 2009
    23
    helo brothas, hope u all can suggest on my query up ther.. thxz... :)
  13. tibay-sniper
    tibay-sniper Super Veteran
    Jan 23, 2009
    1,101
    363
    Cebu City
    hahaha good, up for vixion kit
  14. sniper OCD
    sniper OCD New Member
    Aug 31, 2009
    13
    dumageute
    man i just put my sniper to 190 cc 13.1 compresion.
    ported out the head and everything else i could touch.
    running stock came for break in and then going back to my stage 2.
    doing the math I should hit 28 kw or 32 hp or better.
    ill let you know if it blows when i hit the gas whith my stage 2 cam after break in. neighbors complaning about the noise of bike. its loud loud loud.
    loud pipes save lives , everyone hears me comming lol
  15. sniper OCD
    Aug 31, 2009
    13
    dumageute
    im running a 64 piston with a nicer piston than mollasi. 190cc +
    i used a vixion cylinder
    and bored it out . the honeing is a long drown out procidure as it has to be perfect or your cylinder wont last.
  16. raider125jeigh
    raider125jeigh Super Veteran
    Feb 8, 2009
    6,588
    40
    373
    Metro Manila - Makati City
    and bored it out . the honeing is a long drown out procidure as it has to be perfect or your cylinder wont last.[/quote:2yh2jxbl]
    OT
    Just want to ask what is your top speed.. lot of engine mods for you.. i admire you sir..
  17. chiglai
    Sep 9, 2007
    1,435
    100
    373
    CDOC
    yeah sir.. can like give more details on your mods...
    i do admire people who share a lot on their mods even if its only for racing purpose.. i really cant do much on mods for my bike is still my daily bike and still the bike i use for touring... touring with traxxas aint easy i tell you that.. we only do pits stops for 10minutes i cant even finish a single cig... i do hope your mods will be enough for a long drive.. lets say about 300kms with only 20 minute break for gas? if so that would be very nice for us...
  18. JUNEX
    JUNEX Super Veteran
    May 24, 2008
    2,395
    57
    373
    Earth, Asia, Philippines, Mindanao, Cagayan de oro
    [​IMG]
    this is my dog sparky
  19. valerossi46
    valerossi46 New Member
    Oct 16, 2007
    Where can I get this Malossi big bore kit?
  20. hass
    hass New Member
    Jul 30, 2009
    46
    In Europe we can buy them in the malossi shop .
    http://www.malossistore.be/Default.aspx
    If you want just the big bore without ecu from malossi you must buy the big bore from malossi for Hm or fantic , it's the same but without ecu
    http://www.malossistore.be/Prodotto.asp ... &C=3113214
