1. TAG ME is now enabled.
    Use @username to notify the member that he was mentioned in your post.
    Member that was tagged will be alerted thru Alerts notice.
What Battery Does Your Sniper Use?(show Ur Battery)
Discussion in 'PHILIPPINES: Sniper X1R' started by vanjo03, May 1, 2011.
  1. Lester Chua New Member
    battey life span is only good for 6 months when it passes this time its good na!!!
  2. john_carlo Veteran
    waht do you mean sir..
  3. thon Member
    bro AFAIK battery will last for two years..
  4. snypey16 New Member
    with good maintenance it will last for 3 years like mine still good and reliable.
  5. thon Member
    Lifespan of a Car Battery
    According to the Auto Facts website, a typical car battery lasts about three to five years. However, various factors can affect how long a car battery lasts, especially how the vehicle is driven.
    1. Function
      • A typical car battery is a lead acid battery made up of plates, lead, lead oxide and a sulfuric acid and water solution. The solution is an electrolyte, which generates electricity through a chemical reaction.
      Short Drives
      • If you drive the vehicle short distances every day, the lifespan of the battery will be shorter. Ideally, the alternator should run long enough to recharge the battery.
        Sponsored Links
      Temperature
      • Extreme temperatures can also affect how long a battery lasts. Temperature can affect the chemical reactions inside the battery. This is why battery manufacturers install an insulated jacket.
      Maintenance
      • A good way to get the most life out of a battery is to use terminal protector spray. It cleans terminals and helps reduce the amount of battery corrosion.
      Dead Battery
      • If the battery does die, and it has been about three years since its last replacement, it's best to just replace it. If you don't know how long it's been, you can test it.
    mhektheone and snypey16 like this.
  6. Guiller_99 New Member
    mhektheone likes this.
  7. john_carlo Veteran
    nagtaka nga ako paps na ganun katagal samantalang kung ang baterry ay hanggang 6 months lang bakit pa nagbibigay ng 1 yr warranty sa batery yung mga manufacturer e di nalugi sila
  8. thon Member
    Kaya nga bro 1 year warranty dahil alam nila na tatagal more than 1 year yong life cycle ng battery. Kung magbibigay sila ng 1 year at alam nilang 6 months lang eh di siguradong lugi sila..hehehe..:D
  9. John Angelo Cantal New Member
    gs maintenance free.
  10. HKholic New Member
    Vietnam
    Anitgravity 8-cell Lithium
  11. thon Member
    Ilang AH to bro? Kasya ba ito sa battery compartment ng sniper?
  12. John Angelo Cantal New Member
    kasxa naman xa bro. d ko alam AH nya basta sabi ko lng pang sniper. ;-);-);-)
    1year na dn sakin bro. 1click lng. dati gamit ko motolite maintenance free dn pero 3mnths na busted. baka cguro peke ung nbilhan ko.
  13. thon Member
    Stock battery kasi ng sniper 5ah, kadalasan nakatatak lang yan sa body ng battery. kung mas mataas sa 5ah yan mas magandang gamitin yan.
  14. HKholic New Member
    Vietnam
    Easily. Smaller than stock battery and 1/2 the weight.............with more power. :)
    thon likes this.
  15. mhektheone Veteran
    [IMG] nakita ko lang to dito mukhang maganda sa MC natin to heavy duty to yun nga lang medyo pricee....
  16. John Angelo Cantal New Member
  17. eboitot Super Veteran
    motolite motorcycle batteries, mura tsaka tumatagal din.
  18. ricky0822 New Member
    need help guys! ano po ba magandang brand ng battery for my snipee?
    mukhang kailangan ko ng magpalit kase ayaw ng mag blink ung signal ko at ayaw na ring bumusina
    pero bakit ung estarter ko gumagana pa at last nyt pag uwi ko gumana pa ung HID ko un nga lng wala ako busina... lamat pooo...
  19. John Angelo Cantal New Member
    Gs battery. Maintanance free
  20. snypey16 New Member
    if you are using hid wich usually needs fast charger, maintenance free is not good to use....
    sa tingin ko lang naman po.......
