how about the acceleration using k1 cam? is it really not good on low rpm? or it's just like stock cam?I am using K1 and I am very satisfied with it... My friend was using vixion cams.. We have the same set up except for the cams.. Tried a friendly gauge and infact I won... The vixion cams is more likely same with the stock cams as we compare it... Hope it helps.. cheers
what is the lift of vixion cam sir?.I am using K1 and I am very satisfied with it... My friend was using vixion cams.. We have the same set up except for the cams.. Tried a friendly gauge and infact I won... The vixion cams is more likely same with the stock cams as we compare it... Hope it helps.. cheers
is there any changes it terms of sound of the pipe using this cam from stock cam? i mean in neutral? is there any difference?im currently using k1 cam, it accelerate fast with also top end.
in my set.up it has more aggressive sound using open pipe. but the sound of the cam is more likely on the stock cam, minimal sound produced by k1 cam.is there any changes it terms of sound of the pipe using this cam from stock cam? i mean in neutral? is there any difference?
what is your set.up paps?.how about the acceleration using k1 cam? is it really not good on low rpm? or it's just like stock cam?
you're using vixion bore right?in my set.up it has more aggressive sound using open pipe. but the sound of the cam is more likely on the stock cam, minimal sound produced by k1 cam.
yes paps vixion bore user. pair your RCDI and Vspring with bigger carb paps and cam, then tuned it right.you're using vixion bore right?
okay paps.. thanks!yes paps vixion bore user. pair your RCDI and Vspring with bigger carb paps and cam, then tuned it right.
The acceleration is good. I tried it with a backride(my girlfriend). On one stop, beside me is r150..He was also trying to get a gauge...when the green light is on then both of us accelerate fortunate I leave him..."It should not be done with a back ride and for safety.."how about the acceleration using k1 cam? is it really not good on low rpm? or it's just like stock cam?
sbi nla sir delay ung k1. kung stock pj at mj. delay sya. palit ka lng ng air filter at 17.5pj at 117mj at simota air filter. hnd na yan delay. sabayan mo nrin ng open pipe. sasabay na yan sa saktong piga sa rpm. k1 user here. 57mm with k1 cam. 1yr ko ng gamit. so far so good.how about the acceleration using k1 cam? is it really not good on low rpm? or it's just like stock cam?
nka 57 ka kaya nd na delay hehesbi nla sir delay ung k1. kung stock pj at mj. delay sya. palit ka lng ng air filter at 17.5pj at 117mj at simota air filter. hnd na yan delay. sabayan mo nrin ng open pipe. sasabay na yan sa saktong piga sa rpm. k1 user here. 57mm with k1 cam. 1yr ko ng gamit. so far so good.
stock bore pa ako nun sir. Delayed tlga sya. Ngpalit lng ng jettings. Un ok na sya.nka 57 ka kaya nd na delay hehe
garud iksakto nga jettings bro?? stock bore??stock bore pa ako nun sir. Delayed tlga sya. Ngpalit lng ng jettings. Un ok na sya.
