Bore Upgrading To Vixion
Discussion in 'Engine' started by fmark, Feb 12, 2012.
  1. jiGGer Member
    sori for the ot ts...;);)btt
    up up up
  2. rhoitol Super Veteran
    i used S4-evo cams ang Vixion valve springs sir..base on Idol Macoolet, 600kms to waswas mode..but i gave 80-90kph
    sometimes..not to hard,not to Soft so that the rings fits perfectly or even not so perfectly..
    if the current set up of mine would not matched,, ill try to experiment sprocket combination,
    or try to change the Cams to Higher one..
    setting the engine is one at a time..dont rush things..right combination means satisfaction
    to the owner..right Idol macoolet?...:D
    credits goes to the Modifiers here in T135...you know who you are Guys..thanks..
    Satisfaction is the Death of Desire.
    iamjonmitchell and macoolet like this.
  3. chrisniper19 Member
    Others
    @ rhoitol thanks a lot for sharing bro.. It helps me decide then... :D looking forward to experiment :p
    And i do hope that we can meet one day and that i may had a chance to test ride ur TOY.... :dance:
  4. rhoitol Super Veteran
    no problem idol..
  5. chrisniper19 Member
    Others
    :eek: me idol :p dont be so harsh master :help:... hes jokin....
  6. jiGGer Member
    napaka humble talaga ng mga masters dito sa T135...
    I LOVE IT.!!!!!:inlove::dance:jejejeje
  7. ronald031803 Veteran
    mga paps is the stock sniper cam and vixion cam are the same in lift and degree
    and the valves of two mc are the same in size, in & ex?
    i want to know plss?
    jiGGer likes this.
  8. SPEED RACER Member
    Current set-up of my snipee
    Vixion block kit - squish band by .8mm for better responce
    LHK stage 2 cams
    MTRT valve spring
    MTRT ignition coil
    BRT cdi
    NOB1 aftermarket pipe
    MTRT 4th gear 21t
    FAG crank bearing
    24mm keihin carburetor
    stock sprocket
    so far so good talaga yung vixion block kit laki talaga improvement ng snipee ko sa speed wala ako masabi
    easy lang 150 niya maabot...
    chrisz, takomi, rhoitol and 1 other person like this.
  9. jiGGer Member
    nice one bro....tested na, oem pa...
  10. fmark New Member
    thanks for posting sir.
  11. HKholic New Member
    Vietnam
    I ran a 62mm block with all else stock for 2 months. No problems with the exception of no top end. But the bottom end.....................Holy cow!!!! Bike had tons and tons of torque. Had loads of fun with that set-up.
    nelg_a and allanboy_g like this.
  12. jiGGer Member
    maybe a low speed gearing would do pafz;)
  13. sniperyaz Super Veteran
    if were using stock carb to this block,, is it ok? or we have to rejet our carb? what sizes of jets do you recomend like main jet and pilot jet?
  14. HKholic New Member
    Vietnam
  15. arkhy_sniper135 Veteran
    with my vixion kit plus this mods my my "hinete" aka my rider reach 140kph on 3rd gear 300m then kaboom my engine explodes because of overrev and i didnt yet upgrade to BV ,so my snipee is under hospital now with a destroyed piston and block,valves that are cut into pieces and a damage but can revive head(raider valves)
    vixion kit +additional mods:
    pin 2mm
    yypang cam 5.8 lift
    rcdi
    crg cspring and r.c.lining
    28mm oko carb
    lighten flywheel
    PnP
    STOCK VALVE SPRING(another cause of overrev and valve float)
    and other minor mods.
    additional mods after my sniper is done:
    new vixion kit (ouch!)
    big valves with right vspring(raider valves) to compensate with the higher comp of the engine
    pin balance - lessen the vibration of the engine and to compensate with the load of the engine
    21t 4thgear -to give more power to 4th gear
    57mm dome type = higher comp
    upgrade to 30mm and 32mm carb = depends if for daily use and race use
    this set may follow with your vixion kit upgrade.. Its worthit. More HorsePower t135! :)
  16. JhayBoo Moderator
  17. sniperyaz Super Veteran
    dont forget the valve spring,, because of your valve spring why your engine is kaboom/ explode... cannot take hold much longer of your valve with stock, change it more stiffer than the stock...IMHO
  18. sniperyaz Super Veteran
  19. arkhy_sniper135 Veteran
    yap it will be a more stiffer aftermarket raider 150 valve spring that we will use
  20. HKholic New Member
    Vietnam
    107.5mj & 22.5pj for vm22. It's in there, I just read through all and using translate. :D
