Guys gud day need advice how much lift will I need for 62mm bore kit thanks
fredt135 New Member Mar 30, 2015 #1 Guys gud day need advice how much lift will I need for 62mm bore kit thanks
MaxspeedfromINA New Member Apr 6, 2015 #2 fredt135 said: Guys gud day need advice how much lift will I need for 62mm bore kit thanks Click to expand... Lift for camshaft or stroker up sir do you mean?
MaxspeedfromINA New Member Apr 6, 2015 #4 fredt135 said: both camshaft and stroker Click to expand... raise enough 2mm and camshaft wear CMS is sufficient for the daily use. i had the parts that you need from the camshaft and stroker.
