Minyak Hitam Kering Sampai Enjin Berasap... Tolong Otai2 Semua..
Discussion in 'MALAYSIA: LC150 / 135LC owners' started by fiq123, Jan 1, 2013.
  1. fiq123
    fiq123 New Member
    Jan 1, 2013
    15
    Perak
    trajedi pling truk...
    mto sy bru sj terjd begini.. ptg td.
    sy bru2 ni bru modi mtor.. sy mgunakan myk htam jnis shell AX7.. skrg mto xbley nk start... slalu klo jd mcm ni efek apa kat mtor... n apa yg perlu dilakukan... tlg otai2 semua...
    :help::help::help::help:
  3. phl6684
    phl6684 Moderator Staff Member
    Mar 29, 2008
    4,530
    461
    sungai petani,kedah--->desa pandan,ampang
    xbley start??aritu tuh modi ape je...
    kick start
    1)rasa kosong...xde compression(rasa lembut ja)
    2)ada compression sket tp xleh hidup..
    3)ada compression...tendang tp xhidup2..
    anda pilih...hahahahaha
    1) n 2) valve bocor..trok atau sket2...
    3) pj tersumbat...carb overflow...plug kong...
  4. keciks
    keciks New Member
    Oct 4, 2008
    70
    22
    malaysia
    rind piston dah makan kot.. minyak hitam kering smpaikn brasap..
    lg 1 piston dah crack..
  5. adam_john99
    adam_john99 Super Veteran
    May 5, 2010
    1,018
    212
    KL
    berasap kat mane???compression ade tak??ape spec moto???....
  6. Kidi Sungai Besar
    Kidi Sungai Besar New Member
    Jan 15, 2013
    97
    29
    18
    Sungai Besar - Bandar Baru Bangi
    ape ptot buat untuk elak minyak hitam cepat kering?
    spec moto sy blok 60mm
    cam ride it
    bearing 6305 c3
    cdi kozii
    carb std
    ekzos std
    lain std xde kacau
  7. adam_john99
    May 5, 2010
    1,018
    212
    KL
    1. pastikan takde leaking kat bahagian luar enjin
    2. mase modi dah tukar ke valve seal???
    3. piston ring pasang betul tak???
    4. hos breather kat belah water pump tue ade tersumbat tak???pastikan hos tue clear dari segala halangan.....
    just my sesen jer....
  8. Kidi Sungai Besar
    Jan 15, 2013
    97
    29
    18
    1. pastikan takde leaking kat bahagian luar enjin - da check xde leaking
    2. mase modi dah tukar ke valve seal??? - x tuka valve seal pon mase modi,valve seal yg mane ye?haha
    3. piston ring pasang betul tak??? - piston ring pomen yg pasang kan,tp nanti check balik la
    4. hos breather kat belah water pump tue ade tersumbat tak???pastikan hos tue clear dari segala halangan..... - hos semua clear
  9. adam_john99
    May 5, 2010
    1,018
    212
    KL
    1. CUN
    2. Ha, Valve seal tue duduk kat btg valve , ko kene bukak valve spring baru la nampak valve seal tue.......aku suke tukar valve seal biler cabut head smua sbb malas nak agak samada valve seal lame nie boley pakai ke tak, benda wear n tear. sape pun tatau kondisinyer....lagipun bende nie murah jer....tak sampai rm50/set....
    3. Janji piston ring tue tak selari la garisan die tue.....
    4. CU N
  10. Kidi Sungai Besar
    Jan 15, 2013
    97
    29
    18
    oo,noted..
    valve seal tu ye...ok2
