LED Headlight (another alternative vs HID)
Discussion in 'Electrical' started by zarathos, Aug 27, 2011.
  1. Sidro Veteran
    This is what I do also to my MC, AC magneto drives my headlight using 1 relay (latched type) and the rest are battery operated. And try to replace all of your stock bulb to LED lights(if possible) after modifying to battery operated.
  2. ronald031803 Veteran
    for now, back to 35watts sobra init ng 50w sa head lamp matutunaw ang lens,going to buy auxillary light na projector,me nakita ako sa banawe
  3. SNIPY 135 Member
    mga masters panu b convert ng AC to DC....anung wires ang kailangan i-cut and ikabit...:D
  4. Marc Tefora New Member
  5. Bullet135 Member
    mga master need help here...led na po tail light ko and flasher at working well except po sa flasher both are steady even on high rev po, some suggest to replace my relay, also when headlight and parklight are on super hina po ng busina as in mahina... btw batery operated na po lahat ng lights ko...
  6. ronald031803 Veteran
    bro,low batt ka,you need fast charger,head light bulb is like HID in terms of electric consumption
  7. Marc Tefora New Member
    baka mahina na baterry mo?
  8. ronald031803 Veteran
    bro kelangan mo ng katulad ng kinabit ko kahapon,,,,,,tignan mo sa whats new thread
  9. guitarizta Super Veteran
    sir, is there any modification needed if changing my stock signal light bulb and tail light bulb to LED bulb? by the way, my MC is already converted to DC..
  10. snypey16 New Member
    sir nagpalit po ako ng LED signal light with low wattage than stock bulb pero d po sya nag blink, blink, blink
    xniper03 likes this.
  11. guitarizta Super Veteran
    parang meron ako nabasa na kaylangan mo maglagay ng diode??..pero wait natin mga masters...
  12. automag Veteran
  13. guitarizta Super Veteran
    yung electronic flasher yun ba yung meron 2nog or yung pang-kotse na 2 pin?
  14. automag Veteran
    wala na sya tunog paps saka pang mc talaga sya. parehas pa rin sya ng stock flasher natin kaya plug n play lang sya.
  15. xniper03 Member
    pre mag palit ka ng mas malakas na relay.. nasa bandang headlight yung relay.. para mag blink ang led...
  16. snypey16 New Member
    ang nakalagay dun sir ay 10wx2x12 volts. what specs ng relay na dapat kong ipalit?
  17. xniper03 Member
    cencia paps diko masyado nakita specs ng relay n nilagay ko sa sniper ko which is nabenta ko na... naka mx nko ngayon.. pero paps magtanong ka s mga shop ng motor, for sure meron nun.. kc yung skin talagang nag blink yung t10 led bulb ng nailagay yung relay..
  18. snypey16 New Member
    cge po sir maraming salamat po... ask po ako bukas...
  19. sniper71 New Member
    magkano yan brod???...
  20. sir julius New Member
    na convert ko na ang electricals ko to battery driven/operated. headlight/park light at tail light. question ko nalang is. ok ba nag LED headlight? maganda ba ang liwanag na binibigay ? just wait for the comment nalang.
