ikk primary gear ratio 22/72
Discussion in 'Modification' started by docgabby, Dec 18, 2011.
  1. aizarn20 Member
  2. aizarn20 Member
    sir whats the update of ikk gear on stock tranny?perfect na po ba?
  3. sniping_area Veteran
    very bz lately... sir looking forward this thursday... maybe saturday ill update some pictures..
  4. chie Member
    i think this ratio is not so good:oops:
    -sorry for that but to think its just like adjusting your sprocket combination to a low speed.
    Marc Tefora likes this.
  5. aizarn20 Member
    is that so sir?it means that there will be no improvement in our bike?
  6. chie Member
    -improvement in speed there is, but gust like i have said is just a low speed set-up powerful takeoff but no such top end.
    -this is good in big tire no need to adjust your sprocket combination.;)
  7. aizarn20 Member
    pointers:
    the clutch gear fits on old snipee..
    need hi speed combination sprocket..
    gears need to be set so you'll hear sound on idle mode
    it runs better i think on big bore
    :D:D:D[/quote]
    sir care to explain the red one?
  8. aizarn20 Member
  9. docgabby Super Veteran
    improving the OVERALL performance of our snipers is not dependent on one part alone. its always THE SUM OF ITS PARTS. installing the low speed primary gear TOGETHER with a good transmission ratio will give you gains in performance on your intended purpose. like what chie said, it will produce a better low end (that i need in drag), not much top end. depends on distance traveled. in drag you want your motorcycle quick of the block then reaches 4th gear at the finish, there you manipulate transmission ratio (there are alot of ratios coming out). thats why up to now i am still searching for the ratios i need. is this primary gear good for long rides (often asked) personally i will install it in my daily driver but i will still manipulate the transmission suitable for touring still using the benefit of the increased torque due to low speed ratio this ikk primary gear provides. i am not after top speed always but a balance in the power of the motorcycle.
    jk1122, Marc Tefora and rowan like this.
  10. jk1122 Veteran
    :coffee::thumbsup::thumbsup::thumbsup::thumbsup::cool:..............
  11. sniping_area Veteran
    you will see residue of the gear when you change oil just like changing 4th gear on your tranny
  12. sniping_area Veteran
  13. Marc Tefora New Member
    nice!:thumbsup:wahahaha
  14. aizarn20 Member
    now i know why small sprocket coz mine is 90/80 and 80/80
    SNIPY 135 likes this.
  15. docgabby Super Veteran
  16. sniping_area Veteran
    preng preng preng! :)
    macoolet likes this.
  17. manofsteel27 Member
    subscribing..;)
  18. JhayBoo Moderator
    hi bro, please edit your post, thanks!:)
    Reminder: YOU ARE ON ENGLISH SPEAKING SECTION, Please post in ENGLISH!
  19. aizarn20 Member
  20. macoolet Veteran
    South America
    beep beep..try it in a different approach..
    JhayBoo likes this.
