Howto: Projector Retrofit Headlight
Discussion in 'Modification' started by traxxas-modifier, Dec 19, 2008.
  1. arjaydotcom
    arjaydotcom Veteran
    Jan 3, 2009
    158
    131
    Manila
    danda naman nyan bro.... kaso wla bang gwa na? heheheh....
  2. Azzurri
    Azzurri New Member
    Jul 15, 2008
    162
    11
    33
    Selangor
    actually im looking for retrofit kind of 40mm~50mm diameter...low beam. to replace auxiliary light and create more likely R1 2009 headlight.. :roll:
  3. kurarensu
    kurarensu Veteran
    Jan 3, 2009
    140
    133
    so did anyone manage to try to fit projector lense on the auxiliary lights?? i intend to put 1 projector 1 on each side to work as a headlight... but it seems hard to fit..
    anyone manage to do it pls share wif me hw thx
  4. traxxas-modifier
    traxxas-modifier Super LOLO Staff Member
    Dec 17, 2006
    8,040
    4,197
    438
    gensan
    its possible bro.
    i havent tried it but yes its possible...
  5. kurarensu
    kurarensu Veteran
    Jan 3, 2009
    140
    133
    are u sure bro? then how do you open up the casing for the auxiliary light?
    then for the socket of the t10 is so small, do i have to drill..? care to share cos i got myself single beam projector light but haven try to install..
  6. kurarensu
    kurarensu Veteran
    Jan 3, 2009
    140
    133
    bro i stil waiting for ur projector to be fix on the aux lights.. and after seeing, and if u happen to sell the whole set (aux light + projector) i buy frm u thx
  7. kirawin
    kirawin Veteran
    Feb 23, 2009
    121
    4
    133
    seri kembangan, serdang
    traxxas....if possible...can u buy and send the dual beam light.......
  8. traxxas-modifier
    Dec 17, 2006
    8,040
    4,197
    438
    gensan
    @kurarenso
    bro, i think you really have to find a way to fit it in auxillary light.
    i dont know how to do it now since i havent tried it,
    but as they say,
    "if theres a will, theres a way"
    i only sell projector lights bro, its up to you how to fit it in auxillary light.
    so far this projector of mine is the smallest i find...
    @kirawin
    hi i still have the dual beam light available for sale bro..
    only 1 pc remaining for dual beam light
  9. dude_pare01
    dude_pare01 Super Veteran
    Jun 22, 2007
    788
    11
    343
    Angeles City
    how much on the duals sir traxx?
  10. goff_d_p
    goff_d_p Super Veteran
    Dec 24, 2006
    2,215
    26
    373
    Angeles City, Pampanga.
    I can't wait to get mine, hehehehehehehehe :D
  11. goff_d_p
    Dec 24, 2006
    2,215
    26
    373
    Traxxas, Does the Projector Use the reflector in the Headlight assembly at all?
  12. traxxas-modifier
    Dec 17, 2006
    8,040
    4,197
    438
    gensan
    no bro, it will use the reflector inside the projector
    btw heres the wiring layout for dual beam projector
    [​IMG]
  13. kurarensu
    kurarensu Veteran
    Jan 3, 2009
    140
    133
    bro can pm me the dual..? thanks.. what bulb it uses uh..?
  14. traxxas-modifier
    Dec 17, 2006
    8,040
    4,197
    438
    gensan
    hi bro
    it uses H1 bulb.
    dual beam projector sold out bro.
  15. depedal
    depedal Super Veteran
    Jan 29, 2009
    2,316
    363
    las pinas
    sir may i ask. when you remove the stock bulb socket, do you mean cut off the socket and make a whole with a diameter that the projector will fit in? or the stock bulb socket is just simply un-mounted then the whole is ready for the projector to fit in?
    TIA
  16. mingomz
    mingomz Super Veteran
    Feb 6, 2009
    1,912
    38
    373
    Mandaluyong
    WOW! I like this...how much?
  17. jede
    jede New Member
    Sep 14, 2009
    65
    Valenzuela
    sir how much is your dual beam? thanks
  18. sjeevi30
    sjeevi30 New Member
    Apr 1, 2009
    23
    bro, 2 questions ere
    1) wat do we use to stick the stock headlamp lens back? (material n brand name will b useful)
    2) wat method/equipment do we use to cut out the stock headlamp bulb socket?
    thx in advance..
  19. goff_d_p
    Dec 24, 2006
    2,215
    26
    373
    Traxxas, or anyone who has installed this item.
    I have a concern about heat. I installed this and just 2 minutes being on while I was adjusting it, I noticed that it is very warm, I have a concern about it getting too hot and melting the lens and worse the wiring in the back side.
    can anyone advise me on this? also, Just wondering if I installed this correctly, cause there no label for top or bottom for the projector. which side (top/Bottom) is the solenoid on?
    Thank you guys, please PM me your advise
  20. traxxas-modifier
    Dec 17, 2006
    8,040
    4,197
    438
    gensan
    use HID instead of halogen bulb.
    it will reduce heat...
