gudlak bro hope it wont damage ur head..sniper900 said:Guys is it possible to use the Honda CBR's Piston on our t135? im planning to bore my stock block up to 63.5mm and use the cbr's piston. lets talk :twisted: :twisted: :twisted:
after all, over square engine is the best when it comes to high rpm bikes
Thanks haen for the tips, NOTEDhaen said:very possible... just make sure the pin diameter is the same.. i suggest u make the new cylinder from resleeved vixion block since its water wall is thicker than stock 135 cc block..
edit : dont forget to adjust the cyl head squish area to match the piston's profile.. or u'll just waste lots of potential power.. also please consider the piston's weight..
yup its 15 all right.... maybe a modification on conrod may solve the issue? but it also means no going back to 14fleep said:cbr150's piston pin is size 15
just my 2 cents
