HAZARD LIGHT INSTALLATION
Discussion in 'Electrical' started by Fusionzone, Apr 22, 2007.
  1. guitarizta Super Veteran
    maganda ilagay yta yan dun sa kabila ng susian yung bilog dun...
  2. sabat Member
    isa yn papz s pinagiicipan q! ang kaso lng pg dun nilagay, malayo n xa. atleast sana ung pgla2gyn abot lng din ng kamay q pero no need ng mg 1 hand during riding! . para lng i switch ung hazard ON or OFF..
  3. guitarizta Super Veteran
    paps, you said on your previous posts that the signal light indicator on the meter panel doesn't blink when hazard light is on right?..
    but based on the video you posted the signal light indicator is blinking...how did you do it?
  4. bino46 New Member
    Others
    yes sir you need to turn off your hazard before you switch your turn signal left or right, just like in any other vehicles
  5. ronald031803 Veteran
    ill change the connection of the signal light indicator,i put a new bulb socket with wire, tap the socket wire to the terminal of flasher ,the one wire is ground or negative,the other wire is i forgot to the 2 terminal of flasher,but don't worry you can test it which terminal is working,you can notice the blink is alternate with the signal light and indicator,do not cut the original bulb socket indicator just remove the bulb and place it to your newly install bulb socket
  6. ronald031803 Veteran
    see my hazard light switch?
  7. sabat Member
    can u post it sir! for reference of the other forumers.
    tia!
  8. sabat Member
  9. mhokz Veteran
    Sir pwede ko po ba gamitin yung relay galing sa suzuki shogun pro? para yun nalang sana gagamitin ko
  10. guitarizta Super Veteran
    edited post...
  11. yabzkie New Member
    Sires, may I ask, is it possible to combine in a 4 pole switch the hazard light & the separate blinking park lights of yamaha x1r? Thanks in advance...
  12. Sidro Veteran
    sir just want to clarify with your query. Do you mean your parking light will:
    1. simultaneously blink together with signal lights(hazard function)? or
    2. they are seperate but using the same flasher relay?
    yves likes this.
  13. yabzkie New Member
    Yes sir, they're separate and w/ same flasher relay and combined in 1 switch (4 pole).. Tnx..
    yves likes this.
  14. Sidro Veteran
    hhmm, kinda impossible. but you can try 6 pole double throw switch with off/neutral position because 4 pole alone cannot handle the set-up you want. And replace your stock flasher relay with higher capacity flashers. Just in my own understanding.
  15. yabzkie New Member
    How about sir if i separate the hazard light and the separate blinking of the park light w/ different switches? Is it possible. And also w/ 2 different switches of hazard and park light, can I make it on & off both the hazard & park lights? And if this is possible, can u pls teach me how to do it, what wires will I tap w/ another or another. Thanks.
  16. Sidro Veteran
    Try this one paps, I dont know if sniper and X1r have the same electrical need to look at it first. hazard light switch diagram, just do note you have to replace you stock flasher relay with higher capacity
    and regarding the park light I think your stock switch will do the job, just try this 1 first.
  17. yabzkie New Member
    Thanks sir. Ill try this one. Ill update you if I'm done. Hopefully. Hehe.
    Sidro likes this.
  18. thon Member
    @Sidro will indicator light at speedometer panel lit when hazard switch is on?
  19. Sidro Veteran
    No sir,. In my sniper I replace the stock socket with 2way socket and modify a 2 LED White and blue on my panel for turn indicator.
  20. thon Member
    Hazard light wiring diagram. Stock indicator bulb still working without modification & hazard light working with ignition switch off.
    Cathode of diode1 & diode 2 connected to left & right signal lights ( chocolate & dark green). Use 1n5401 (3ampere diode).
Topics on this page
  1. make hazard lamp on motorcycle
  2. how to install hazard to motorcycle
  3. how to install hazard lights on a motorcycle
  4. how to install hazard light wiring diagram,
  5. how to make hazard light in motorcycle,
  6. intall hazzard light on motorcycle,
  7. hazard light installation for motorcycles,
  8. www.thread and forum on yamaha t135 motorcycle,
  9. connect to negative on hazard light switch,
  10. how to install hazard on motorcycle
