DIY. Valve Clearance
Discussion in 'Tips and Tricks' started by medichloreans, Jan 20, 2007.
  1. medichloreans
    medichloreans Veteran
    Dec 19, 2006
    250
    133
    If someone in the forum knows how to DIY Valve clearance..
    please share it...
    It stated on manual (M'sian Edition)..
    we have to check valve clearance every 6k km...
  3. chinus
    chinus New Member
    Dec 22, 2006
    20
    singapore
    wao !!! cub need to do valve clearance every 6 k hmm -.-"
  4. medichloreans
    Dec 19, 2006
    250
    133
    12k km is a must..
    6k km is precaution perhaps..
    if got a prob with valve...
  5. chinus
    chinus New Member
    Dec 22, 2006
    20
    singapore
    thanks for the info :D
  6. stroker
    stroker Veteran
    Dec 17, 2006
    274
    133
    I've seen more than enough bent valves on even stock T135s... Scary.
  7. medichloreans
    Dec 19, 2006
    250
    133
    phew...
    stroker..
    care to elaborate???
    bcoz of what??
    engine modification??
  8. stroker
    stroker Veteran
    Dec 17, 2006
    274
    133
    Nope. Still quite baffled as to why did such a thing happened.. Many of the T135s that had bent valves are fully stock machines. Just happened without warning, neither is the engine highly stressed when it happened.
    Will update if we can find the slightest clue. Cheers
  9. Frozen Fire
    Frozen Fire Veteran
    Dec 19, 2006
    288
    133
    jakarta
    many happens because they run the machine over rev oftenly
  10. zamron79
    zamron79 New Member
    Dec 21, 2006
    95
    wat difficulties will the rider face wen experiencing a spoilt/bent valves?
  11. stroker
    stroker Veteran
    Dec 17, 2006
    274
    133
    That's one of the prime suspect. But some sh!t did happened to bikes with stock CDI (with rev limiter) too.
    Cheers
  12. MioBikerBoyz
    MioBikerBoyz Super Veteran
    Jan 10, 2007
    1,809
    12
    363
    Thailand
    Is it serious if you buckle up your valves and what effects will happen?
  13. rooster
    rooster Super Veteran
    Feb 17, 2007
    1,890
    363
    EAST JAVA
    will changing the valve spring with a higher spring rate will avoid valve stamping and what are the negative side effects by performing this without changing other parts? thx
  14. Frozen Fire
    Frozen Fire Veteran
    Dec 19, 2006
    288
    133
    jakarta
    your valve may be broken if spring coefficient changes... FYI, valve clearance is set every 9000 km, I have done it twice on my 17xyz kms bike
  15. rooster
    Feb 17, 2007
    1,890
    363
    EAST JAVA
    thx...
  16. traxxas-modifier
    traxxas-modifier Super LOLO Staff Member
    Dec 17, 2006
    8,040
    4,199
    438
    gensan
    is it true that we need to set valve clearance at 6000km ?
    what will happen if you will not reset it at that mileage?
  17. Frozen Fire
    Frozen Fire Veteran
    Dec 19, 2006
    288
    133
    jakarta
    9000km, if not, your mileage become worst, engine begin to sound noisely, and you can't run the engine any smoother or faster, in the end if your cam chain loosen, the worst case is you'll break your valve cause misstiming of valve opening and closing
  18. medichloreans
    Dec 19, 2006
    250
    133
    my neighbour also use same bike..
    yamaha t135..
    same age, almost 8 month...
    only mileage makes a difference..
    mine only 8k km++ but his bike almost reach 20k km...
    he still not adjusting valve clearance..
    only do regular maintenance...
  19. MioBikerBoyz
    Jan 10, 2007
    1,809
    12
    363
    Thailand
    what is valve clearence???
  20. traxxas-modifier
    Dec 17, 2006
    8,040
    4,199
    438
    gensan
    valve clearance is the space or clearance of your engine valve.
    as time/usage goes by, it changes the valve clearance...
    sound of your motorcycle will also change due to change in valve clearance.
    IT IS A MUST TO ADJUST THE VALVE CLEARANCE OF YOUR T135
    IN 6000KM ODOMETER AS PER ADVISED BY YAMAHA
    it states in your motorcycle manual maintenance schedule
  21. clicked
    clicked New Member
    Mar 6, 2007
    137
    31
    saw someone in singaporebike forum,he is riding honda sonic,sayin that he has change a titantium valve,whack e bike oso nvm...if T135 has tt shd we stil worry abt bent valve? or stil hav to do clearance?
