cdi: rextor or brt
Discussion in 'Modification' started by thopiang, Oct 7, 2009.
  1. Mono
    Mono Super Veteran
    Feb 11, 2010
    5,200
    806
    CamilingTarlac - QuezonCity 360°
    meron...
  2. thabz
    thabz Super Veteran
    Nov 22, 2010
    332
    341
    Antipolo, Cogeo Padilla.
    sarap brt dual band user here :)
    and For Sale narin Brandnew Brt Dual band cdi's :)
  3. sniper_eds
    sniper_eds Super Veteran
    Mar 7, 2008
    413
    5
    343
    Cebu City
    pano malalaman kung peke ang CDI
  4. thopiang
    thopiang Super Veteran
    Aug 19, 2009
    1,589
    177
    cotabato city
    been a user of these 2 cdis, i think rextor performs way better then brt, kaso dapat palagi maintain voltage ng battery kasi madali lang masira ag lobatt ang motor
    brt dual band, plug and play, ok din gamitin and cheaper than rextor
    currently using brt dual band but will replace it soon with tdr cdi
  5. rikuo27
    rikuo27 New Member
    Dec 26, 2009
    57
    cavite
    guys, by the next two weeks, me and my buddies will be having our 3rd annual out of town ride. it seems i'm being the slowest now..i ride a sniper ac..my mechanic suggested i upgrade my cdi and camshaft.. i already got an LHK 1st stage cam shaft and planning on buying a brt dualband cdi. will these be enough to increase my bike's power? the only upgrade i had before is an open pipe. currently my top speed is 110kph. i want to go up by 10kph more and increase acceleration.
    what other upgrades can i do on my bike. by the way, i'm not into drag or circuit racing..i use my bike goin to work and some joyride..but still i wanna go fast. hehehe! thanks.
  6. (sukiyama)
    (sukiyama) Veteran
    Feb 18, 2009
    195
    20
    136
    pitstop garage
    mga paps, ano ano ba kulay ng brt cdi hyperband pang sniper, me naka pagsabi sakin mas ok daw yung kulay blue na hyperband. bawat kulay ba iba iba pa performance. thanks
  7. Noah501
    Noah501 Super Veteran
    Apr 8, 2011
    556
    51
    Cagayan de Oro City
    How much does rextor Costs? Interested.:)
  8. BuZzMoNk3y
    BuZzMoNk3y Super Veteran
    Aug 16, 2010
    694
    102
    city of generals
    @Noah-just pm traxxas...
  9. tolitz
    tolitz Super Veteran
    Mar 8, 2011
    1,886
    458
    Biñan
    jusTwanna ask if its true that when i replace cdi, it will increase the power of my mc. For now my top speed is 120kph. With all stock i havent replace anything.
  10. david16
    david16 New Member
    May 11, 2011
    92
    10
    Quezon, City
    nice topic I learn a lot. and. most. of the. topif is informative thumbs up!
  11. samt135nz
    samt135nz New Member
    May 5, 2011
    50
    bali
    Indonesia
    and if you buy the tune-up/racing......what else do you need to change????
  12. zcbitik
    zcbitik Super Veteran
    Mar 23, 2011
    2,317
    561
    Bulacan
    guys can anyone explain/elaborate this two brand of BRT?
    BRT powermax dualband VS. BRT Hyperband, my bike is for daily drive po
    as per sir wingman brt hyperband is good for daily drive.. if that's the case,.. can I still use the powermax dualband for my daily drive? what are the difference between that two? please please please.. help!!!
  13. win
    win New Member
    May 26, 2011
    mga sir... pno ba pag cdi ng mio ang gamitin. sbi my binabaliktad lng n wire. alin dun?
  14. xer028
    xer028 Super Veteran
    Dec 16, 2010
    2,022
    182
    TARLAC (SCOT)
    REXTOR still no.1 for me...all in ONE! adjustable RCDI..
    Share ko lang po:
    Rextor adjustable cdi especially designed for Yamaha T135 with FULL THROTTLE POSITION SENSOR (TPS) support and Thermosensor FAN support.
    Rextor Adjustable CDI for Yamaha T135have builtin 30 folders that contains Ignition Timing Mapping Graphs.
    This means for every 0.04volts of change in TPS sensor, a specific folder with graphs is used for better performance. The graphs were dyno tested to provide better performance on all powerband.
    Adjustable CDI for T135 uses Motorola" Microprocessor featuring Motorola" MC908QY4 Technology
    This adjustable cdi for Yamaha T135 also provides additional features
    - Advanced the ignition timing upto 4 degrees.
    Advance the ignition timing by turning the dial counter clockwise
    - Retard the ignition timing upto 4 degrees.
    Retard your ignition timing by turning the dial clockwise.
    - LED red light indicator for ignition timing
    You can use this red led light to know if you want to use stock ignition timing or advance or retard setting.
    - LED green light indicator for TPS with TPS TUNER.
    You will know if your TPS is functioning properly thru this led greenlight.
    You can also use this led green light to properly tune/adjust your TPS
    in correct angle. The correct angle for your TPS is important so that
    you will have the best performance.
    - Radiator FAN function checker.
    the rextor adjustable cdi for yamaha t135 will check if your fan is working properly. Every ignition on, The radiator fan will turn on for 4 seconds. No more worrying to know if your fan is working or not.
    - Thermosensor Overheat Temperature Support
    The rextor adjustable cdi for yamaha t135 supports overheat temperature sensor. Your temperature will light (panel meter) if your engine overheat. so you dont need to worry about your engine.
    -Dyno Tested and No revolution limiter
    this means you will now experience better speed and acceleration due to no rev limiter. And all ignition graphs used were tested using dyno meter.
    i personally use this Rextor adjustable CDI in my bike and im very satisfied due to FULL support of TPS and FAN sensor with additional features that cannot be find in stock cdi. Plus added top speed and acceleration!
  15. kit
    kit Veteran
    Jun 16, 2011
    209
    25
    143
    Daet, Camarines Norte
    namban user here 1 socket(no tps,heat temp)...color yellow, just got it last week, still under observation, but definetaly better than stock
  16. kit
    kit Veteran
    Jun 16, 2011
    209
    25
    143
    I think u lost power cuz of openpipe... no pressure..best pipe for stock engine is stock pipe, been there done that, just my 2cent
  17. lpsnipie_67
    lpsnipie_67 Super Veteran
    Mar 14, 2010
    635
    102
    368
    Philppines
    only for rasing bro...;)
  18. lpsnipie_67
    Mar 14, 2010
    635
    102
    368
    Philppines
    BRT plug n play (hyper & dualband) no worry to adjust anything + tps / fan ;)... REXTOR V3 adjustable with tps / fan :)... enjoy the ride...
  19. lpsnipie_67
    Mar 14, 2010
    635
    102
    368
    Philppines
    you can rev it according to what you want :rolleyes:....
  20. lpsnipie_67
    Mar 14, 2010
    635
    102
    368
    Philppines
    yup! :(
