carb modification
Discussion in 'Modification' started by traxxas-modifier, Feb 10, 2008.
  1. jval15 Super Veteran
    nosebleed me :?
  2. sniper31 Super Veteran
    Me?, nose bleeding! So many expenses...
  3. lanno New Member
    Traxx, i would appreciate if you could explain of how the standard carb do function including the Main Jet and Pilot Jet plus tuning the two buttons outside the carb. Thx Bro
    p/s: if possible in overrall the function of the stock carb.
  4. lanno New Member
    not forgrtting thr jrtting as well. How is these all inter related to each other to give out better performance to the stock blok or extra large block.
  5. turbulence Member
    Sir, base on the drawing on the air flow, woudn't it be better to remove the whole choke holder? So there will be no intervention with the air flow?
  6. traxxas-modifier Administrator
  7. turbulence Member
  8. axon Veteran
    IMHO,
    from stock engine, changing carb. means we need a more fuel and more air, and a good SP but imagine the stock intake and exhaust stem valve, and the manifold between head and carb. the inner diameter does not change means the air velocity and air volume entered in combustion chamber still the same, then why we need to upgrade for bigger carb if we're still in stock mode? what i mean is stick with our stock and focus on head work first, our engine is 4t not 2t in 4t we have cam and valves means we have a duration for opening and closing of this 4 valve unlike 2t only reed valve, that's why the 2T engine produce more rpm than 4T even the 2T engine has smaller capacity, i'm gonna touch my carb if i change my 4 valves to bigger size, if re-jetting and spark plug color checked does not work well then that's the time for bigger carb. just a cents of noob idea...
    please feel free to enlightened me ...
  9. arttribe_sniperT135 New Member
    wheeww!!! grabe . !! marami pah aqng ka2ining gas. . ai Bigas plah. para mkarelate s knila!! traxxas thumbs up seneo.!!!
  10. j_caldeojr New Member
    I just have a little question regarding on the stock carb for the sniper, what is the stock main jetting of the stock carb and the pilot jet also for the stock carb?
    Thank you very much
  11. Juz Lance New Member
    You said tmr mjn 28mm rm1600..
    Where you get it..?
    If confirm that price, i want it..
    massage me at this email..
    zvzul@yahoo.com or FB 'Juz Lance'..
  12. Juz Lance New Member
    How much this carb..? Massage me at this email zvzul@yahoo.com.. TQ.
  13. traxxas-modifier Administrator
    that FCR28 carb cost around usd$600 :)
  14. Juz Lance New Member
    how about tmr-mjn 28mm..
  15. Munawir Zackry New Member
    WTB Yoshimura Caburetor size for everyday use only ! PM ME PLS
  16. fiq rocketeer New Member
    hi traxxas.can u give me link for manual of keihin carburator? i like to gain knowledge bout keihin
