YamahaT135.COM Jupiter MX Yamaha Sniper Exciter Crypton X LC4V Spark 135 motorcycle owners...
  Home   •  Forum   •  Picture Album  •  Search  •  Preferences  •  Register  •  Profile  •  Log in to check your private messages  •  Log in
View next topic
View previous topic
YamahaT135.COM  » Yamaha Market » For Sale » SNIPER, SPARK, CRYPTON X, EXCITER - T135 BIG VALVE HEAD
Post new topicReply to topic View previous topicEmail to a Friend.List users that have viewed this topicSave this Topic as filePrintable versionLog in to check your private messagesView next topic
Author Message
haen
ACTIVE MEMBER
ACTIVE MEMBER
Modification Specs: PROTEC GROUND COIL + CRYO'ed PLUG, TDR + REXTOR CDI, DAYTONA KEVLAR Clutch Plate,
62 mm SPECIAL BLOCK, TK RACING Valve Spring, MIKUNI TM28 SUDCO, TDR CONE AIR FILTER, KITACO SHOCK, SINNOB SPROCKET, A LITTLE MOD HERE AND THERE, R9 MUGELLO NG, 22/19 BIG VALVE HEAD FLOWBENCH PORTED, SPECIAL POWER CAM, H.I.D HI-LO HEADLAMP
PostPosted: Tue Nov 25, 2008 2:25 pm  Post subject: Great ! SNIPER, SPARK, CRYPTON X, EXCITER - T135 BIG VALVE HEAD Reply with quoteBottom of PageBack to top
Hi, Bros and Sis
Something to add the juice is coming..
1. BIG VALVE HEAD for T135
perfect couple for stock block (21/18 setup),
gives more power with Vixion block, 60 mm and 60.5 mm block
First Flavour : 22/19 Big Valve Head
BIG VALVES 22/19 config.. RESQUISHED..
Second Flavour : 22/18 and 21/18 Big Valve Head TK Racing
2. AVAILABLE TOO for STOCK BLOCK :
TK RACING VALVES 19/17 gives more power and torque (based on dyno tests increase max 0.9 - 1 HP)
COMBINE this with TK VALVE SPRING.. feel the additional power and torque !
23/21 CONFIG IS AVAILABLE TOO, JUST PM ME
as usual :
ask price and questions by PM please, as this is a for sale thread.
payment method : PayPal, Western Union/MoneyGram, Wire Transfer
contact pm or YM id : haentiara
Thank you.
Aquarius Gender:Male Tiger HiddenPersonal Gallery of haenView user's profileSend private messageYahoo Messenger
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Tue Nov 25, 2008 2:32 pm  Post subject: Idea (No subject) Reply with quoteBottom of PageBack to top
The stuff would come in a few days, here's the preview of the TK Racing valves... THEY'RE ALL SWIRL POLISHED.. UNDERCUT STEM..
See the angles...
justkir
NEWBIE
NEWBIE
Modification Specs: Uma Racing 28mm Carby, OEM Airbox, 60.5mm piston, BRT Imax Smart Click CDI, ABM Cam, Faito Clutch Spring, Ride It Valve Spring, Racing Kitty 21t 4th Gear, Sprocket 15-36
PostPosted: Tue Nov 25, 2008 7:40 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
what can i say! WOW!
Scorpio Gender:Male Dog OfflinePersonal Gallery of justkirView user's profileSend private messageYahoo MessengerMSN Messenger
Administrator
Administrator
Modification Specs: all stock....
i mean all stock parts are gone! :-)
PostPosted: Wed Nov 26, 2008 12:00 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
wowowee!
whats the difference with tk valve and stock valve bro?
   OfflinePersonal Gallery of traxxas-modifierView user's profileSend private message
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Nov 26, 2008 12:23 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
@traxxas : hi good boy.. LoL.. still tweaking tat cool TMR-MJN ?
The difference between stock valve :
1. Material
2. Valve profile
3. Valve finishing (sandblast like).. look at the tip
4. Valve diameter (+1, +2)
5. Non magnetic characteristics prevents foul build up
In general, it's already made to increase the gas flow, compared to stock.
Also, the 19/17 is PLUG & RACE .. lol.. no hassles..
vnduck
NEWBIE
NEWBIE
Modification Specs: Exciter 135 with R1 Galfer wave rotors, R1 front master & CRG lever, Brembo rear cylinder, Ducati 748 Brembo 2 pis caliper & brake lines, front and rear. X1R mag and handle bar, Koso gauge. R6 intergrated tail light & hotbodies undertail signals, Nui racing steps. Vixion kit + race cam & valve head, Mikuni Tm28-1 bumper carb.
PostPosted: Wed Nov 26, 2008 6:27 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Why are you doing this to me!!!?!?!?!?! Shocked
Seriously man, keep doing this and u will never get my package out of the way because i just keep adding new stuff into it!!!! Evil or Very Mad
hehe
   OfflinePersonal Gallery of vnduckView user's profileSend private message
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Nov 26, 2008 9:32 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
@vnduck : hahhahahahah.. dont worry.. it'll be on ur way this week and be the first to taste it... thanx
justkir
NEWBIE
NEWBIE
PostPosted: Wed Nov 26, 2008 12:37 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
yeahhh....i also feel that way...muahahha
haen, if i may ask, what type of material of the head? same like oem?
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Nov 26, 2008 7:29 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
@justkir : lets chat by YM..
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Thu Nov 27, 2008 10:48 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
dyno chart results from local tabloid for TK VALVE review..
increased peak power and torque.. this is just using stock valve size..
justkir
NEWBIE
NEWBIE
PostPosted: Fri Nov 28, 2008 3:55 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
respect...the differences very huge on the power band....
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Dec 03, 2008 11:32 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
HI GUYS and GALS, this is a dyno test result using VIXION STOCK KIT and BIG VALVE HEAD (22 mm and 19 mm config), taken from the courtesy of my friend.. u can see that with optimum tuning the result is awesome.. the only mod done on the bike is only carb change using PWK 28 mm and Big Valve head...
BEFORE BIG VALVE UPGRADE
ImageBy haen1974 at 2008-09-15
AFTER BIG VALVE UPGRADE
3rd GEAR
4th GEAR
max power changed from previous config (shown above) using only PWK 28 carb and Racing CDI, from 18,7 HP @9200 rpm and torque 14,63 Nm @8189 rpm to 21,9HP @10215 rpm and torque 16,44 Nm @8606 rpm, a difference of 3,2 HP
Will post the BIG VALVE HEAD TK RACING 22/18 setup results soon...
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Dec 10, 2008 12:51 pm  Post subject: Idea (No subject) Reply with quoteBottom of PageBack to top
STOCK SIZE TK RACING VALVE 19/17 .. look at the angles and profile..
COMPARISON BETWEEN 22/18 (left side) and 19/17 (right side)
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Sat Dec 20, 2008 6:44 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
POLISHED & PORTED INLET
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Tue Dec 23, 2008 12:32 am  Post subject: Great ! (No subject) Reply with quoteBottom of PageBack to top
TK RACING BIG HEAD... take a look at this baby...
22/18 Racing Valves..
VALVE GUIDES.. 5 mm diameter valve compared to 4.5 mm STOCK.. stronger valve..
One more shot..
Administrator
Administrator
PostPosted: Tue Dec 23, 2008 3:31 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
how i wish santa will give this bigvalve next year Smile
justkir
NEWBIE
NEWBIE
PostPosted: Tue Dec 23, 2008 9:53 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
yes indeed!
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Jan 07, 2009 6:50 pm  Post subject: Great ! DYNO RESULTS FOR THE TK RACING VALVES Reply with quoteBottom of PageBack to top
Here's our dyno results on the TK Racing Valves.. tests performed with this config :
Keihin PWK28 KX100 (tuned up by Thole)
Cheetah Power CP450 programmable CDI
TK Racing Valves 22/18 setup
V-Ixion Block and Piston
STOCK CONROD
..bro Sydney.. thanks for the help bro.. !
Our little research proves that we can have durability (57 mm vixion block) and power resulting in..
23 HP !!
Top Speed (on Dyno).. > 150 kmh
By haen1974
By haen1974
4th GEAR
By haen1974
Sydney
NEWBIE
NEWBIE
Modification Specs: Yamaha Jupiter MX : PWK 28 mm KX 100 Carburetor, 23 In & 19 Ex Valve, Custom Camshaft and Spring Valve, Porting and Polish Cylinder Head with shaving off 0.7 mm, Custom 135 cc Cylinder with 60.5 mm Piston, Cheetah Power 450V Programble CDI, YZ 125 Coil, Denso IU 27 Spark Plug, Custom Racing Exhaust.
PostPosted: Fri Jan 09, 2009 1:30 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
your welcome bro.., with all my pleasure thanks for this project.
Next project is 169 cc tune with big valve head.
guess/target it what horsepower will you get from this mod..??
Gemini Gender:Male Dragon OfflinePersonal Gallery of SydneyView user's profileSend private messageYahoo Messenger
jayded1
NEWBIE
NEWBIE
PostPosted: Fri May 01, 2009 8:09 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Haen,
This head is the bomb....i cant wait to install it.
   OfflinePersonal Gallery of jayded1View user's profileSend private message
Display posts from previous:
View next topic
View previous topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
6524 Attacks blocked
