| Author |
Message |
vtec29
 NEWBIE
Modification Specs: Future ; 5th gear transmision
hi..i'm new here....
Bro, how about v-ixion gear box..is it will fit with t135..?pm mi the price an to KL..
TQ
extremeT135
 NEWBIE
Modification Specs: itchy knees
Can you PM me the price for the completed package including shipping cost to Vietnam?
sniper_eds
 NEWBIE
Modification Specs: Yamaha Sniper Old (2007) and Sniper 2009/2010 Model red-black
pls pm me about the price including shipping to philippines
aromeo
 NEWBIE
Modification Specs: Yamaha crypton x
135lc
 NEWBIE
Modification Specs: std engine (speed kill!!) manual clutch rear 125z disc brake front/rear 125z sport rims
p.m. about price + shipping price in RM to pulau pinang,malaysia.
haen
 ACTIVE MEMBER
Modification Specs: PROTEC GROUND COIL + CRYO'ed PLUG, TDR + REXTOR CDI, DAYTONA KEVLAR Clutch Plate, 62 mm SPECIAL BLOCK, TK RACING Valve Spring, MIKUNI TM28 SUDCO, TDR CONE AIR FILTER, KITACO SHOCK, SINNOB SPROCKET, A LITTLE MOD HERE AND THERE, R9 MUGELLO NG, 22/19 BIG VALVE HEAD FLOWBENCH PORTED, SPECIAL POWER CAM, H.I.D HI-LO HEADLAMP
@all : thanx for your interest on the kit, please just send pm to me for price inquiries and questions
 Administrator
Modification Specs: all stock.... i mean all stock parts are gone! :-)
gogogo! buy haens vixion block
haen
 ACTIVE MEMBER
hohoho.. anybody wanna go for 60 mm block, big valves too ?
thrasher
 NEWBIE
Modification Specs: Just a lil bit of creativity.
definitely, provided its good, reliable, and has a decent price tag too.
haen
 ACTIVE MEMBER
goff_d_p
 REGULAR MEMBER
I was one, but just can't afford it now. I need the economy to go back up and the US dollar to Peso exchange rate to go back up to P55. for every $1.00 at the least. more would be better.
anhe
 NEWBIE
give me the price(include shipping).I'm from VN.and some price for Tk valve Spring,daytona clutch.
Thanks
VHANZ
 NEWBIE
Modification Specs: - Jupiter MX Manual Clutch. - Custom Big Bore Block (200cc LC). - Custom Camshaft (Duration 3** Degree - Valve Lift 9,5mm). - Custom Big Valve Head (2* in - 2* ex). - CDI XP ANDRION 301MC LE Stage02 06 Power. - Coil XP ANDRION CMC-2A. - KEIHIN PE-28 Carb (Reamed). - DENSO Iridium IU31. - Japan Stiffer Valve Spring. - TK Clutch Spring. - YSS GP-MONO Monoshock.
Woooowwwww..... Hi Bro Haen....meet you again in here....
Mahal juga yach warung sebelah jualan Bore-up Kit 60mm-nya hahahahaha... LoL
Ockay... good luck my bro...
haen
 ACTIVE MEMBER
hussshhyy.. don't use local language here bro.. hohohoh.... thanx
nadlina7
 NEWBIE
Modification Specs: 70/90 front 80/90 rear standard tyres 15 front 36 rear sss sprocket 428HD sss chain brt dualband cdi keihin PE28mm carb cam 'R' valve spring 'R' modified head 58.5mm block custom modi pipe exhaust rx-z catalyzer footrest
haen bro.
pls pm me the price including the shipping fees in MYR...
thanx..
haen
 ACTIVE MEMBER
HI GUYS and GALS, this is a dyno test result using VIXION STOCK KIT and BIG VALVE HEAD (22 mm and 19 mm), taken from the courtesy of my friend.. mr. Sydney (Dzaki Wardana)... u can see that with optimum tuning the result is awesome.. the only mod done on the bike is only carb change using PWK 28 mm and Big Valve head...
BEFORE BIG VALVE UPGRADE
By haen1974 at 2008-09-15
AFTER BIG VALVE UPGRADE
3rd GEAR
4th GEAR
max power changed from previous config (shown above) using only PWK 28 carb and Racing CDI, from 18,7 HP @9200 rpm and torque 14,63 Nm @8189 rpm to 21,9HP @10215 rpm and torque 16,44 Nm @8606 rpm, a difference of 3,2 HP
charge
 NEWBIE
thanks bro, that's a nice dyno chart. btw, does your fren use any racing cam or stiffer valve spring?
haen
 ACTIVE MEMBER
@charge : stock vixion cam with custom valve spring
haen
 ACTIVE MEMBER
HELLO.. from now on.. those who purchase this kit would get a FREE LIMITED TK VALVE SPRING for orders til 31 Dec 2008
vnduck
 NEWBIE
Modification Specs: Exciter 135 with R1 Galfer wave rotors, R1 front master & CRG lever, Brembo rear cylinder, Ducati 748 Brembo 2 pis caliper & brake lines, front and rear. X1R mag and handle bar, Koso gauge. R6 intergrated tail light & hotbodies undertail signals, Nui racing steps. Vixion kit + race cam & valve head, Mikuni Tm28-1 bumper carb.
Nice, l love you man!!!!!!
Give me one or two more week to get my thing together, then .... )
Goto page Previous 1, 2, 3, 4 ... 20, 21, 22 Next
topicviewbottom
View next topic
View previous topic
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
