YamahaT135.COM Jupiter MX Yamaha Sniper Exciter Crypton X LC4V Spark 135 motorcycle owners...
  Home   •  Forum   •  Picture Album  •  Search  •  Preferences  •  Register  •  Profile  •  Log in to check your private messages  •  Log in
View next topic
View previous topic
YamahaT135.COM  » Yamaha Market » For Sale » 150cc DIASIL, 178 cc and 188 cc SPECIAL BOREUP KITS
Post new topicReply to topic View previous topicEmail to a Friend.List users that have viewed this topicSave this Topic as filePrintable versionLog in to check your private messagesView next topic
Author Message
haen
ACTIVE MEMBER
ACTIVE MEMBER
Modification Specs: PROTEC GROUND COIL + CRYO'ed PLUG, TDR + REXTOR CDI, DAYTONA KEVLAR Clutch Plate,
62 mm SPECIAL BLOCK, TK RACING Valve Spring, MIKUNI TM28 SUDCO, TDR CONE AIR FILTER, KITACO SHOCK, SINNOB SPROCKET, A LITTLE MOD HERE AND THERE, R9 MUGELLO NG, 22/19 BIG VALVE HEAD FLOWBENCH PORTED, SPECIAL POWER CAM, H.I.D HI-LO HEADLAMP
PostPosted: Sat Mar 08, 2008 6:52 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
hi d'expert,
to apply the vixion block u dont have to change anything, well, maybe some.. it's recommended to step up the pilot jet to #22,5 and main jet to #105.. don't have to change anything beside the lower liner of the vixion cyl block, but that already done and u just have to install it.. it's entirely plug and play.. but those stuff (pj, mj, cam etc) already included in the whole kit anyway..
remember, cam change is recommended, either using vixion cam or the street performance cam.. t135 stock cam is too 'low profile'...
Some very popular tips :
Dismiss the decompression assy, sometimes it's activated when the engine is revving at high rpm, making compression loss.
Aquarius Gender:Male Tiger HiddenPersonal Gallery of haenView user's profileSend private messageYahoo Messenger
dehanz
NEWBIE
NEWBIE
Modification Specs: Stock! It's all about riding skills. :-)
PostPosted: Sun Mar 09, 2008 12:14 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
what is decompression assy?
 Gender:Male  OfflinePersonal Gallery of dehanzView user's profileSend private messageSend e-mail
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Tue Mar 11, 2008 9:20 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
it's an assy that attaches to cam gear, it pushes the pin so the exhaust valve would open to reduce compression, making it easy to start, but the side effect is there too
kamalez
ACTIVE MEMBER
ACTIVE MEMBER
Modification Specs: still doing one by one
PostPosted: Wed Mar 12, 2008 12:20 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Is it a must to dismiss decompression assy when install Vixon block or Yamaha racing cam.
What re side effect if have done them?
 Gender:Male  OfflinePersonal Gallery of kamalezView user's profileSend private messageAIM AddressYahoo MessengerMSN Messenger
Administrator
Administrator
Modification Specs: all stock....
i mean all stock parts are gone! :-)
PostPosted: Wed Mar 12, 2008 12:43 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
bro haen what is the
advantage/disadvantage if it will not be removed?
also
advantage/disadvantage if it will be removed?
   OfflinePersonal Gallery of traxxas-modifierView user's profileSend private message
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Mar 12, 2008 2:12 pm  Post subject: Idea (No subject) Reply with quoteBottom of PageBack to top
Its not a must to remove the decompression assy when installing Vixion block, it's just a way to increase performance.
But for my super cam, it is a must to remove the decompression assy, because it'd disrupt the duration of the exhaust valve.
also
advantage/disadvantage if it will be removed??
IF NOT REMOVED :
Advantage : easy to start whether using electric or kick start
the kick start wont 'bounce' back when u kick it
Disadvantage : because its working mechanism relies on engine rpm to throw it out of contact with the pin on the cam, sometimes when the rpm hits 1500-2000 its activated and makes ur engine lose compression, try this at gear 3 to gear 4 change, because the gear 4 ratio is soooo different, the rpm drops suddenly and makes this mechanism active and u get loss in performance.
IF REMOVED :
Advantage : no more compression loss of course
no 'sudden performance drop'
Disadvantage : depends on ur cam profile, it need a stronger force to kick start ur engine, if the cam lift is very high (higher compression), you might need stronger battery to start the engine using electric starter.
IN GENERAL,
decompression assy is just a feature with its plus and minus side, so it wont hurt ur engine if you remove it or not remove it.
It's your choice, do u want max performance, or ease of start ?
ANOTHER TIP,
close the AIS line on the cyl head, because it disrupts exhaust process.
kamalez
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Mar 12, 2008 4:09 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Thanks for the great info,
i still don't have idea which one is the decompression assy
Administrator
Administrator
PostPosted: Wed Mar 12, 2008 8:32 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
@kamalez
decompression assembly is shown in the parts catalogue.
check it out
@haen
thanks for the info bro. very good info.
more question, decompression assembly activates at what specific rpm?
is that the reason why theres so much difference in the 3rd gear to 4th gear?
if we remove decomp assmbly, will the 3rd to 4th be smooth? no more loss of power?
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed Mar 12, 2008 10:07 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
thats decomp assy...
technically, decomp assy should be activated only on rpm under 1500.. but u know.. sometimes something happen...
yes, thats why gear 4 dropped soooo much....
one more tip :
if u r reluctant to throw away the decomp assy, then...
if you have the time, dont use that lower cyl gasket, throw it and use threebond sealer as replacement, so u got more compression without too much modification.. dont worry, lower cyl gasket doesnt relate piston movement..
h4hahak1m
NEWBIE
NEWBIE
Modification Specs: Yamaha Sniper
PostPosted: Thu Mar 13, 2008 1:15 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
one more tip :
U got pictures of that article bro? I know where the decomp assy but i dun understand what u mean by dismissing it
   OfflinePersonal Gallery of h4hahak1mView user's profileSend private message
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Thu Mar 13, 2008 1:35 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
@h4hahak1m
yah.. look at the picture.. that's what i mean by dismissing the decomp assy.. use only the gear.. as for the rest of the parts, it's either keep it or throw it away.. hehehehe....
p.s
That no lower cyl block gasket tip is quite effective.. threebond seals the gap effectively.. enjoy the performance increase.. especially combined with the super cam or v-ixion cam.. still unsatisfied ? add the vixion block upgrade.. still want more ? upgrade the carb and the CDI
s.m.i
NEWBIE
NEWBIE
Modification Specs: Yamaha SPARK 135
PostPosted: Thu Mar 13, 2008 10:25 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
wow!!hey pm mi the price an to s'pore...thanks
Aries Gender:Male Tiger OfflinePersonal Gallery of s.m.iView user's profileSend private message
Administrator
Administrator
PostPosted: Thu Mar 13, 2008 11:01 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
very good info bro!
keep it up!
mansormj
NEWBIE
NEWBIE
Modification Specs: lc 135
PostPosted: Thu Mar 13, 2008 11:37 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
traxxas-modifier wrote:
very good info bro!
keep it up!
hi,
I olso need that prices, can send that quote.
tq.
mansormj
Scorpio Gender:Male Cat OfflinePersonal Gallery of mansormjView user's profileSend private message
M_fikriLC
NEWBIE
NEWBIE
Modification Specs: factory standard..no mods.
PostPosted: Thu Mar 13, 2008 11:44 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
oh my god......its too good to be truth..
Aries Gender:Male Goat HiddenPersonal Gallery of M_fikriLCView user's profileSend private messageSend e-mail
gechz22
NEWBIE
NEWBIE
Modification Specs:
kitti E1 camshaft, stoker pin ( 2mm ), port n polish, rear set, rear disc brake, fender eliminator,ride it rims (1.85 r/ 1.60 f),trusty fork housing
PostPosted: Sun Mar 16, 2008 3:15 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
hi bro.. can u pm regarding the price of the package if u send it here in dubai.. thanks in advance
Aquarius Gender:Male Dragon OfflinePersonal Gallery of gechz22View user's profileSend private message
thrasher
NEWBIE
NEWBIE
Modification Specs: Just a lil bit of creativity.
PostPosted: Fri Apr 11, 2008 12:43 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
any comments from anyone who tried and tested this? from my understanding v-ixion is fuel injection technology. won't it be in conflict with a carburetor version of t135?
   OfflinePersonal Gallery of thrasherView user's profileSend private message
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Fri Apr 11, 2008 12:51 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
hi thrasher.. v-ixion block is the same block as T135.. head, cylinder etc and internal parts are the same.. except some difference on cam duration and lift.. and the diameter of the cyl block, piston, piston pin, and surface profile of the piston..
Administrator
Administrator
PostPosted: Sun Apr 13, 2008 2:01 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
that means it will fit with t135 bro Smile
thrasher
NEWBIE
NEWBIE
PostPosted: Wed Apr 16, 2008 1:33 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
heh. i dont really know much abt it. so pardon my stupidity. heh heh.
Display posts from previous:
View next topic
View previous topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
6604 Attacks blocked
