YamahaT135.COM Jupiter MX Yamaha Sniper Exciter Crypton X LC4V Spark 135 motorcycle owners...
  Home   •  Forum   •  Picture Album  •  Search  •  Preferences  •  Register  •  Profile  •  Log in to check your private messages  •  Log in
View next topic
View previous topic
YamahaT135.COM  » Yamaha Market » For Sale » 150cc DIASIL, 178 cc and 188 cc SPECIAL BOREUP KITS
Post new topicReply to topic View previous topicEmail to a Friend.List users that have viewed this topicSave this Topic as filePrintable versionLog in to check your private messagesView next topic
Author Message
haen
ACTIVE MEMBER
ACTIVE MEMBER
Modification Specs: PROTEC GROUND COIL + CRYO'ed PLUG, TDR + REXTOR CDI, DAYTONA KEVLAR Clutch Plate,
62 mm SPECIAL BLOCK, TK RACING Valve Spring, MIKUNI TM28 SUDCO, TDR CONE AIR FILTER, KITACO SHOCK, SINNOB SPROCKET, A LITTLE MOD HERE AND THERE, R9 MUGELLO NG, 22/19 BIG VALVE HEAD FLOWBENCH PORTED, SPECIAL POWER CAM, H.I.D HI-LO HEADLAMP
PostPosted: Mon Jan 14, 2008 4:05 pm  Post subject: Great ! 150cc DIASIL, 178 cc and 188 cc SPECIAL BOREUP KITS Reply with quoteBottom of PageBack to top
150 CC DIASIL SPECIAL RECIPE PACKAGE :
150 cc KIT touched and TUNED on some parts by me (after Jan 1 st, 2009 purchases)
This CAM
+ VALVE SPRING
DYNO TEST spec :
Mikuni TM28 PJ 17,5 MJ 215
TDR Cone Air Filter + stock airbox
CLD Competition Pipe Header + NOB1 3BOLD silencer
Power Cam 5.8
Cryogenic Vixion Valve Spring
Head 22/19 Flowbench ported
Intake Kitaco
CDI TDR + Rextor
Final Gear 15-39
Gearbox Close Ratio :
1st - 33/13
2nd - 29/17
3rd - 23/17
4th - 23/21
FAG Hi Speed bearing
The kit are :
KIT UPDATE
PACKAGE I : 150 cc KIT
1. BASIC KIT
1. Piston ring set
2. Piston kit
3. Piston pin
4. Cyl block
5. Cyl gasket (lower)
6. Cyl head gasket
7. Water Pump O-ring
8. STAGE 2 CAM
9. Circlip
10. Valve Spring
2. 150 cc TUNED UP KIT, BIG VALVE HEAD READY with modification at :
1. Modified piston
2. Shaved block
3. SPECIAL POWER CAM 5.8 mm lift in replacement of the Stage 2 cam
4. Protec GROUND ULTIMATE coil
DYNO TEST RESULT FOR THE TUNED UP KIT with ABOVE TEST SPEC
ALL ORIGINAL PARTS !!! contact me by email for pricing and shipping..
PACKAGE II : 178 CC 62 MM KIT (BLOCK, PISTON, PISTON WRIST PIN, PISTON RING SET)
Description : 62 mm forged piston, special steel bore, water jacket, piston rings, piston pin, gaskets
still use stock 14 mm conrod plug and ride
Special 62 mm forged piston with special cyl block.. no leak, no heat up issues
PIC HERE : http://www.facebook.com/photo.php?pid=4221883&id=320505998430
DYNO TEST RESULT
Uploaded with ImageShack.us
PACKAGE III :188 CC KIT (BLOCK, CONROD, PISTON, PISTON WRIST PIN, PISTON RING SET
Description : 64 mm piston, special steel bore, water jacket, piston rings, piston pin, conrod 15 mm pin hole
NOTE : for 178 and 188 cc KIT, THE VALVE SPRING and POWER CAMSHAFT are INCLUDED
Instantly you'll get 150cc, 178 cc and superb acceleration...but the best thing is...
IT'S TROUBLE FREE AND POWER PROVEN YET STILL SAFE FOR DAILY AND LONG RIDE !!!
These came from a long research which costs time, money and lot of effort..
NEW ! CRYO TREATMENT at small ADDITIONAL COST
What's to be treated ? Here they are :
1. Piston
2. Piston ring
3. Piston pen
4. Cyl block
and what is this CRYO TREATMENT actually ?
Read here :
http://www.metal-wear.com/
pm me for price..
Guaranteed to make u cry... gear two on my 86kg weight reaches 85 km /h FAST !!! EDIT : now my weight is 92 kgs... :D
So there's what are available for now..
I'm on Indonesia..
Pay by PayPal, wiretransfer or Western Union
contact pm or Yahoo messenger ID haentiara
Aquarius Gender:Male Tiger HiddenPersonal Gallery of haenView user's profileSend private messageYahoo Messenger
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Mon Jan 14, 2008 4:06 pm  Post subject:  here's the complete kit image Reply with quoteBottom of PageBack to top
glenah
NEWBIE
NEWBIE
Modification Specs: stock ...
PostPosted: Mon Jan 14, 2008 9:37 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
just asking , how about the timing chen?
Gemini Gender:Male Horse OfflinePersonal Gallery of glenahView user's profileSend private messageAIM AddressYahoo MessengerMSN Messenger
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Mon Jan 14, 2008 9:59 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
timing chain ? what about it ? all the timing parts are same as our T135, part code and physical attributes are identical to every bit of it.. yamaha only added a small chain plastic cover part, coded 3C1-E2256-00 just for additional accessory..
surkrew
NEWBIE
NEWBIE
Modification Specs: 150cc vixion block 58mm piston, super cam, racing cdi, racing valve spring, racing clutch spring, Kevlar clutch plate, uma 28mm carb, YSS rear shocks, Dunlop tt900 (80/80 front & 90/80 rear) and yy pang racing exhaust, 14-45 sprocket
PostPosted: Tue Jan 15, 2008 4:22 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
pm me the price dude.. including shipping to brunei..
Scorpio Gender:Male Pig OfflinePersonal Gallery of surkrewView user's profileSend private messageVisit poster's websiteMSN Messenger
glenah
NEWBIE
NEWBIE
PostPosted: Wed Jan 16, 2008 5:01 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
ahh ic .. thanks . and how much is that?
zerocool
NEWBIE
NEWBIE
Modification Specs: nothing
PostPosted: Wed Jan 16, 2008 8:01 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
pm me the price including shipping to singapore
Cancer Gender:Male Pig OfflinePersonal Gallery of zerocoolView user's profileSend private messageSend e-mailMSN Messenger
CryptonX
NEWBIE
NEWBIE
Modification Specs: removed the euro3 catalizer 14tfront sprocket and hard brake in :P
PostPosted: Thu Jan 17, 2008 12:07 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
look at the piston its not a high performance one its a piston for long live Wink
Sagittarius Gender:Male Snake OfflinePersonal Gallery of CryptonXView user's profileSend private messageSend e-mail
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Sat Jan 19, 2008 9:47 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
not a long life only crypton, it was designed that way so the valve lift can be increased 1 mm more than stock T135, but that if using V-Ixion's camshaft, that's why if we're upgrading the block only without camshaft change, the improvement is just mild
dennis_808
NEWBIE
NEWBIE
Modification Specs: modified rider
PostPosted: Sat Jan 19, 2008 7:24 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
hi haen,can you pm me the details about how to order the kit from your place and shipping.tnx!
 Gender:Male  OfflinePersonal Gallery of dennis_808View user's profileSend private messageSend e-mailYahoo Messenger
charge
NEWBIE
NEWBIE
PostPosted: Sun Feb 03, 2008 1:36 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
a quick question. from Vixion spec, we need 1.2L of engine oil, but T135 only got 0.8L tank. Where to get the tank?
Taurus Gender:Male Pig HiddenPersonal Gallery of chargeView user's profileSend private message
pange_air
NEWBIE
NEWBIE
Modification Specs: Yamaha LC
PostPosted: Sun Feb 03, 2008 2:28 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
pm me the best price include shipping to malaysia Very Happy
Capricorn Gender:Male Cock OfflinePersonal Gallery of pange_airView user's profileSend private message
rudduan
REGULAR MEMBER
REGULAR MEMBER
Modification Specs: stock model
PostPosted: Sun Feb 03, 2008 10:40 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
no need to get tank,just add full 1liter of the engine oil,empty the bottle
Virgo Gender:Male Tiger OfflinePersonal Gallery of rudduanView user's profileSend private messageSend e-mail
anthonyvinh
NEWBIE
NEWBIE
Modification Specs: kitti exhaust pipe.
PostPosted: Fri Feb 29, 2008 9:03 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
i'm in Vietnam, how to buy Vixion Block,pm price include shipping, thanks
   OfflinePersonal Gallery of anthonyvinhView user's profileSend private message
D'Expert
NEWBIE
NEWBIE
Modification Specs: Yamaha Sniper
PostPosted: Sat Mar 01, 2008 7:17 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
pls p.m. about price including shipping.
Capricorn Gender:Male Monkey OfflinePersonal Gallery of D'ExpertView user's profileSend private message
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Sat Mar 01, 2008 8:21 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
hi anthony, hi d'expert.. check ur PM please
unlimited express
ACTIVE MEMBER
ACTIVE MEMBER
Modification Specs: ... stock ang driver....
PostPosted: Sat Mar 01, 2008 9:41 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
hey haen, did you get my inquiries? could you PM me for the price including the shipping to Philippines please. will I get all the stuff in the picture and everythin mentioned above? Thanks dude...
 Gender:Male  HiddenPersonal Gallery of unlimited expressView user's profileSend private message
haen
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Tue Mar 04, 2008 6:29 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
hey unlimited.. i already sent u reply.. dunno somehow the system didnt send it..
unlimited express
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Tue Mar 04, 2008 10:04 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
got it bro. thanks
D'Expert
NEWBIE
NEWBIE
PostPosted: Sat Mar 08, 2008 3:07 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Haen, may i know if i need to modify something to enable to accomodate the vixion block?
Display posts from previous:
View next topic
View previous topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
5814 Attacks blocked
