YamahaT135.COM Jupiter MX Yamaha Sniper Exciter Crypton X LC4V Spark 135 motorcycle owners...
  Home   •  Forum   •  Picture Album  •  Search  •  Preferences  •  Register  •  Profile  •  Log in to check your private messages  •  Log in
View next topic
View previous topic
YamahaT135.COM  » Yamaha T135 Discussions (ENGLISH SPEAKING AREA) » Modification » My peformance digital gauge veypor vr2 for T135
Post new topicReply to topic View previous topicEmail to a Friend.List users that have viewed this topicSave this Topic as filePrintable versionLog in to check your private messagesView next topic
Author Message
Administrator
Administrator
Modification Specs: all stock....
i mean all stock parts are gone! :-)
PostPosted: Thu May 24, 2007 1:18 am  Post subject:  My peformance digital gauge veypor vr2 for T135 Reply with quoteBottom of PageBack to top
ok been busy for the past days installing my veypor vr2 performance gauge in my bike.
so far i already installed it temporarily and do the wirings permanently.
check my installation procedures below.
the veypor vr2 box
Note:   the veypor vr2 box
the veypor vr2 gauge. small and handy
Note:   the veypor vr2 gauge. small and handy
the contents of veypor vr2
Note:   the contents of veypor vr2
finding the right place to install the magnet sensor in the rear sprocket
Note:   finding the right place to install the magnet sensor in the rear sprocket
remove the rear sprocket and drill it so that the magnet sensor will be inserted.
Note:   remove the rear sprocket and drill it so that the magnet sensor will be inserted.
after drilling, insert the magnet sensor to the hole.
Note:   after drilling, insert the magnet sensor to the hole.
Note:   insert the magnet sensor
now its inserted, add some glue to it so that it wont fell off. You dont want to loose that tiny magnet!
Note:   now its inserted, add some glue to it so that it wont fell off. You dont want to loose that tiny magnet!
now install the speed sensor in your swingarm. The speed sensor is located inside that black tube. It should be direct area of the magnet when sprocket revolves. Else speedmeter will not read.
Note:   now install the speed sensor in your swingarm. The speed sensor is located inside that black tube. It should be direct area of the magnet when sprocket revolves. Else speedmeter will not read.
closeup view of the black tube with sensor inside it.
Note:   closeup view of the black tube with sensor inside it.
actually the black tube is a piece of rubber. inside it are a cable connected to the speed sensor. I just put the cable inside the black tube for added protection :)
Note:   actually the black tube is a piece of rubber. inside it are a cable connected to the speed sensor. I just put the cable inside the black tube for added protection :)
install the wiring harness according to the manual. I dissassemble the wiring harness out of curiosity. I hope my warranty will not be voided :)
Note:   install the wiring harness according to the manual. I dissassemble the wiring harness out of curiosity. I hope my warranty will not be voided :)
Last edited by traxxas-modifier on Tue Oct 23, 2007 2:10 am; edited 3 times in total
   OfflinePersonal Gallery of traxxas-modifierView user's profileSend private message
Administrator
Administrator
PostPosted: Thu May 24, 2007 1:48 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
other pictures and descriptions for the installation of Veypor VR2 performance gauge.
Anyone wants to buy it cost USD$315 from the manufacturer site veypor.com,
PM because I can give you BIG DISCOUNT from the manufacturer Smile
now the white wire is looped to the ignition coil wire going to the spark plug.
The manual states that i connect the white wire to the supply from CDI to ignition coil (t135 orange wire) But.. it wont work!! so i just looped it around.
Note:   now the white wire is looped to the ignition coil wire going to the spark plug.
Now for testing... i inserted the wiring harness and fireup the engine!
Note:   Now for testing... i inserted the wiring harness and fireup the engine!
and its running!!! oh the idle is on 1150rpm. Out of spec! Need to set the idle screw to make it on 1300-1500 rpm range. No next morning maybe. Time to sleep.
Note:   and its running!!! oh the idle is on 1150rpm. Out of spec! Need to set the idle screw to make it on 1300-1500 rpm range. No next morning maybe. Time to sleep.
its morning! wow!! what a nice view :)
Note:   its morning! wow!! what a nice view :)
idle speed already changed. moved the location of the vr2 gauge on the left side mirror for better view.
Note:   idle speed already changed. moved the location of the vr2 gauge on the left side mirror for better view.
another angle.
Note:   another angle.
now a test drive.. and i love it!!!
Note:   now a test drive.. and i love it!!!
the permanent mess on our garage :)
Note:   the permanent mess on our garage :)
during the wiring installation
Note:   during the wiring installation
Last edited by traxxas-modifier on Tue Oct 23, 2007 2:12 am; edited 3 times in total
Administrator
Administrator
PostPosted: Thu May 24, 2007 2:25 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
my next project?
install it permanently and replace the stock gauge with this vr2 Smile
rooster
REGULAR MEMBER
REGULAR MEMBER
Modification Specs: i can get you parts and stuffs for t135 from indonesia
PostPosted: Thu May 24, 2007 11:01 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
wow i envy u i wanna get that veypor thing... Sad
Cancer Gender:Male Cock OfflinePersonal Gallery of roosterView user's profileSend private messageYahoo Messenger
Glowplug
NEWBIE
NEWBIE
PostPosted: Fri May 25, 2007 9:37 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
What are the gauges or indicators aside from tachometer? does it also indicates speed, water temp, fuel level etc?
And how much?
 Gender:Male  OfflinePersonal Gallery of GlowplugView user's profileSend private message
kamalez
ACTIVE MEMBER
ACTIVE MEMBER
Modification Specs: still doing one by one
PostPosted: Fri May 25, 2007 10:02 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Nice work Traxxas - Please advice the funtionality of this Veypor.
If i were yo install at my bike, it will gone within few minutes. Lot of thieves down here
 Gender:Male  OfflinePersonal Gallery of kamalezView user's profileSend private messageAIM AddressYahoo MessengerMSN Messenger
pyro13
NEWBIE
NEWBIE
Modification Specs: itchy knees
PostPosted: Fri May 25, 2007 3:54 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
does the Veypor comes wit speedo??
wanna fix it as my meter..but its way too expensive here..
abt 120 USD just for the item.
and i would send to the mechanic to fix it will cost abt USD 50
   OfflinePersonal Gallery of pyro13View user's profileSend private message
surkrew
NEWBIE
NEWBIE
Modification Specs: 150cc vixion block 58mm piston, super cam, racing cdi, racing valve spring, racing clutch spring, Kevlar clutch plate, uma 28mm carb, YSS rear shocks, Dunlop tt900 (80/80 front & 90/80 rear) and yy pang racing exhaust, 14-45 sprocket
PostPosted: Fri May 25, 2007 4:13 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
i've googled it and apparently, it's all in one device.. speedometer, rpm, fuel consumption and level, lap time, track time (with some additional accessories i think), mapping and transfering of data to pc/laptop and a few more functions that i forgot ehehhe
Scorpio Gender:Male Pig OfflinePersonal Gallery of surkrewView user's profileSend private messageVisit poster's websiteMSN Messenger
Administrator
Administrator
PostPosted: Fri May 25, 2007 6:46 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
And how much?
Speed, tachometer, Fuel gauge, Acelleration, Hp, Torque, data logger, time/date. Mileage. Everything except water temp.
Its also a Portable Dynamometer to measure the hp of your bike.
if you install it outside your bike, its not recommended to leave it. because it can be steal.
I would recommend to replace the stock gauge with this veypor (what im doing soon)
yes it comes with speedometer and its very highly accurate.
if you change your tire size, you can configure it to do the speedometer changes
and make it accurate again.
see the magnet i installed in the sprocket.
thats the magnet for the sensor in the swingarm.
Anyone wants to buy it cost USD$300 from the manufacturer site veypor.com,
rooster
REGULAR MEMBER
REGULAR MEMBER
PostPosted: Fri May 25, 2007 9:29 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
300 us $...wow..
id rather get the 300cc conversion blocks for my t135 only 400 US $ here...
kakakaka
Glowplug
NEWBIE
NEWBIE
PostPosted: Sat May 26, 2007 8:22 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
traxxas I could only say WOW!!!!, with that features you can easily tune your bike because it has all the indication again WOWOWOWOW! I'll think about it.
Hey Rooster, can you spell out the specs on the 300cc conversion kit, again WOW!
Glowplug
NEWBIE
NEWBIE
PostPosted: Sat May 26, 2007 8:41 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Hey traxxas have you check if there is a difference in speed between veypor and the stock speedo?
Administrator
Administrator
PostPosted: Sat May 26, 2007 6:45 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
yes bro.
the very first measurement i made is to check the difference of stock speedo. heres a summary
stock 40 = veypor 37kph
stock 50 = veypor 46kph
stock 60 = veypor 55kph
stock 70 = veypor 64kph
stock 80 = veypor 73kph
stock 90 = veypor 82kph
stock 100 = veypor 91kph
stock 110 = veypor 100kph
stock 120 = veypor 109kph
but i need to verify it again with video so that
we can see also the rpm at every speed.
just a tip:
stock rev limiter kicks in at 9200rpm
the above measurements are just visual.
i have to make a test again using a datalogger and
verify the results by downloading the data at a pc.
in the meantime i cant do it since my plate number was lost.. (
due to my carelessness.
CarroTT
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Sat May 26, 2007 9:30 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
try revving it up at 2nd gear on the road till it hits the rev limiter
shot a video of it Laughing
 Gender:Male  OfflinePersonal Gallery of CarroTTView user's profileSend private message
tsunami
ACTIVE MEMBER
ACTIVE MEMBER
Modification Specs: Called Me shadowmaster "0195766174"
PostPosted: Sun May 27, 2007 8:02 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Huhu brave trying...
Aquarius Gender:Male Goat OfflinePersonal Gallery of tsunamiView user's profileSend private message
rooster
REGULAR MEMBER
REGULAR MEMBER
PostPosted: Mon May 28, 2007 12:30 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
well the coversion kits is VERY extreme cant use the cooling system no more..u want?
kamalez
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Mon May 28, 2007 8:49 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Traxxas - The veypor ver2 is expensive, but there are many features which is very use full can be obtained and download to PC. For example the charasistic of your bike with stock parts and once you upgrade to racing parts, there would difference in which data can be tabulated. By this way you could advice us what is the best after market parts would be really use full to our bike interims of increase in power.
tsunami
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Mon May 28, 2007 4:57 pm  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Hmm i think all parts of those Vepor Ver2 is useful to make it works perfectly
Administrator
Administrator
PostPosted: Wed May 30, 2007 2:02 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
yes bro thats what ill be doing.
measure stock performance
-change iridium plug, measure performance
-change air filter to k&n, measure performance
-change cdi, measure performance
and other mods...
but not now, probably later on july...
because i have very important event this coming june Smile
kamalez
ACTIVE MEMBER
ACTIVE MEMBER
PostPosted: Wed May 30, 2007 8:39 am  Post subject:  (No subject) Reply with quoteBottom of PageBack to top
Hi Traxxas - Shall wait for your valueble info. Keep safe on the veypor, bro those things are hi-tech and eye catching
Display posts from previous:
View next topic
View previous topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You can download files in this forum
6524 Attacks blocked
